08-10-2011 08:40 PM
Hi All!
Is there a way to "subscribe" to a post without responding to it? A lot of times I see posts for which I dont have an anwer but I'm definetely interested on seeing what the other people responds. However I havent found a way to "watch" a discussion (get emails notifications and things like that when others respond) . Is there a way to do this?
If not could I submit this as an enhancemente request hehe.
Thanks a bunch!!!!
Raga
Solved! Go to Solution.
08-11-2011 04:18 AM
Hi Raga,
Yes, you can subscribe to posts without responding to it. Start off by going to the discussion you want to watch. Be sure you are logged in and look in the "actions" widget in the right navigation. You should see an option for "receive email notifications". Just click on that and you're set.
Cheers,
Dan
08-11-2011 04:18 AM
Hi Raga,
Cheers,
Dan
08-11-2011 07:33 AM
Got it Thanks!!!
10-14-2014 03:21 AM
Apparently the page has been redesigned since this answer three years ago. Now when I look at "Actions" I see only the options
Create Blog
Create Discussion
Create Document
Create Video
but nothing about receiving email notifications; however, there is now a "Follow" button and another "Follow" link on the page, both of which seem to do the same thing.
I have a slightly different question: I would like to be notified when the router I use is mentioned in posts. Is there a way to arrange for that?
10-14-2014 08:47 AM
Correct me if I'm wrong, but I think you are looking for email notifications based on keywords? You could simply choose a product and any mention of that product would send you a notification. If that is the case, it is something we have investigated in the past and do have on our road-map.
Cheers,
Dan
