Duplex PG problem
deyaa.salama
Frequent Visitor
Frequent Visitor
A Customer have ICM 7.2.7 with ISN. we have configured duplexed PG for the ISN. when we start the two sides one of them is connected to the router and the PGAG process is INSERVICE and the other side PGAG OOSERVICE. the router gives the following error
Device PG02 attempted to connect but is already connected.
And  the PG MDSPROC process gives me the other peer is not reachable despit of succes PING on the privat ip.
I have make sure of the private interfaces. i tried to use the ip addresses instead of hostname, the same issue happend.
jondawson
Frequent Visitor
Frequent Visitor
Sounds like you might have one PG set to run duplexed and the other side is not.  Check setup on both PG's and ensure that they both have the duplexed box ticked.
Cheers,
JD
