12-27-2006 10:24 AM - edited 03-14-2019 12:23 AM
I am trying to capture the CCDR call id so that it can be passed along to the CAD desktop. This way the agent can then enter it as part of the call notes within the customers third party app. This will help the customer identify what CCDR record was for what call.
Solved! Go to Solution.
12-28-2006 12:19 PM
You may be able to use a Get Contact Info step to retrieve the "Implementation ID" which is equivalent to the Global Call Identifier within CallManager which should be recorded in the CCDRs.
Please rate useful posts.
12-28-2006 12:19 PM
12-28-2006 01:06 PM
I may have misread your requirement. If you need to record an IPCC CCDR (Contact Centre Detail Record) identifier, rather than a CallManager CDR reference, then looking at the database schema:
you may be able to use the Session ID (using the same Get Contact Info step). Alternatively, the Session Sequence number is unique to each call leg.
