ACI APIC Network-As-Code interface configuration
Hi, I have difficulties configuring vpc port to a couple of leaf-switches.
I'm using Network As Code trying to do this. (https://netascode.cisco.com/data_model/apic/interface_policies/new_interface_config)
But I'm not able to understand how to do it.
I have 2 files with NAC.  One that creates the vpc policy group (L601..602:1:1_VPCIPG_TEST), and that works fine.
The other file is meant to configure the interface, like you do in GUI (Location in GUI: Fabric » Access Policies » Interface Configuration).
Here I want to configure vpc for leaf 601 and 602 with eth1/1 and the L601..602:1:1_VPCIPG_TEST as the policy group.
But I'm not able to understand how to do this.  Anyone have any tip on how to do this?
7 Replies 7
I am not sure what learning platform this is, they have some examples here https://github.com/orgs/netascode/repositories
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
mfr-6
Hi @Geir Sand-Strand
If you want to use new interface configuration (using interface policies) you need to set new_interface_configuration to "true", otherwise this part of configuration would be ignored.
Please provide me your configuration you've prepared so far, I'll try to assist you on this (including your terraform code where you set up your NAC module).
Usually, you need to configure Policy Group first: https://netascode.cisco.com/data_model/apic/access_policies/ap_leaf_interface_policy_group - here you'll set a type to "vpc" to have desired result.
then - https://netascode.cisco.com/data_model/apic/interface_policies/new_interface_config/ - under interface, where policy group is required - you need to select policy group previously created.
If this is not clear enough for you - please provide me your configuration that you tried to apply. If you can't go through this - that's completely fine, I'll guide you step by step what you need to do, but It would be easier for you to explain things on something you tried to implement.
Looking forward to hearing from you!
Mateusz Frak NetDevOps | DevNet | Automation DevNet Expert #20240068
Please mark this post as helpful if it solves your issue, to make this visible for other users, thank you!
I tried this in my *.nac.yaml file:
apic:
  access_policies:
    leaf_interface_policy_groups:
      - name: TEST_All_PG
         type: access
         aaep: All_Domains-AEP
         cdp_policy: CDP_Enable
  new_interface_configuration: true
  interface_policies:
    nodes:
       - id: 601
         interfaces:
             - port: 1
                policy_group: TEST_All_PG
               description: 601_TEST_All_PG
But this doesn't create the interface configuration.  The main.tf is set to true:
manage_access_policies = true
manage_fabric_policies = true
manage_pod_policies = true
manage_node_policies = true
manage_interface_policies = true
manage_tenants = true
This is a test environment so no problem doing some testing.
I have tried to modify an exsisting interface configuration, and also a different interface.  No luck in doing any interface configuration.
Creating vcp, pc or access port under policy group is working fine.
Br Geir
Since this enviroment is not a total greenfield with NAC, the nodes exists already.
But I did a test "creating" the node_policies, and the tried the interface configuration.  It worked.
But is it really necessesary to create the node policies first?
hi @Geir Sand-Strand
I just tested your setup and just like you said (I didn't see your last response, sorry) - the missing bit was leaf node policy not defined.
Yes, this is mandatory, because NAC Module looks up for all nodes defined in a datamodel and iterates through them and then through inner "interface_policies" list, to create interface policies for each interface defined as long as "new_interface_configuration" option is set to "true".
That said - if node is not defined under "node_policies", then the code would never reach the state where interface_policies are created. Leaf node policy and interface_policy has a hard relationship, where interface policy cannot live without node policy (composition in a programming).
If you have a brownfield fabric, then you should consider importing node_policies into your terraform setup so those are controlled by TF + Nexus as Code, so you can later manage interface_policies for all leafs in your fabric.
I hope that helps. If you have more questions - feel free to ask!
dolahler
Frequent Visitor
Frequent Visitor
Hi Mateusz,
I am this very specific junction with an existing ACI fabric where automation was never part of the equation  when it was put in almost 7 years ago.
"If you have a brownfield fabric, then you should consider importing node_policies into your terraform setup so those are controlled by TF + Nexus as Code, so you can later manage interface_policies for all leafs in your fabric."
I don't have fancy Nexus Dashboard to play with and now left with open-source options. Gitlab CI/CD + TF came into my mind but could you please point me to the right direction to use automation with TF as SoT. I know it will not be quick or without pain. Thanks
hi @dolahler
I didn't have Nexus Dashboard in mind and you don't need it at all to become successful with Terraform and Nexus as Code, so you'll be completely fine with open source solutions.
The challenging part for you is to get your running configuration of  your fabric being managed by Terraform as part of CI/CD pipeline without making an impact to configuration. Obviously it's so easy to set the fabric up from the scratch using Terraform, but we definitely don't want to build everything from scratch and what's worse - destroy the fabric and stop switches to forward the packets.
First stage would be to make Terraform aware about your configuration and this process is often called "importing" resources (objects/configuration parts) into statefile (Terraform's database so it knows all the details about config it manages).
Cisco as a part of professional services can help you with this and get your brownfield fabric migrated to nexus as code so it starts to fully manage your environment.
If you need to do that on your own, you need something that would take your APIC snapshot and translate it into yaml representation of a datamodel, so later on you can perform import operation in Terraform and gradually start making Terraform aware about your resources step-by-step performing import operation.
I'd love to say it's easy and quick, but unfortunately it isn't. This requires a lot of effort and developing in-house solution that would literally take your snapshot and translate it into yaml datamodel files and then developing (or automating) the terraform import process. Depending on a size of your config and how complex it is - another thing to consider is splitting resources across different statefiles (workspaces it's called in nexus-as-code nomenclature) because you don't want terraform to manage 50k resources... performance is significantly degraded - been there, done that.
