ACI Programmability Options- Devnet Lab- Stuck on Step 1 :(
petersmiddy
Frequent Visitor
Frequent Visitor
Hi all,
I'm stuck with a problem on ACI Programmability Options lab, section APIC Sandbox Environment Setup:
https://learninglabs.cisco.com/modules/intro-to-aci/sbx-intro-aci-02_programmability-options/step/1
It says:
# From within the correct virtual environment (venv) apic_fabric_setup\ $ python baseline.py
# Expected Output
Baselining APIC Simulator for Learning Labs
Setting up Fabric Nodes
Configuring Fabric Policies
Setting up Common Tenant
Setting up Heroes Tenant
Setting up SnV Tenant
But my output is:
(venv) C:\workingdir\aci-learning-labs-code-samples\apic_fabric_setup>python baseline.py
Traceback (most recent call last):
  File "baseline.py", line 11, in <module>
    import startup_script
  File "C:\workingdir\aci-learning-labs-code-samples\apic_fabric_setup\startup_script.py", line 3, in <module>
    import cobra.mit.access
  File "c:\workingdir\aci-learning-labs-code-samples\venv\lib\site-packages\acicobra-3.0_1k-py2.7.egg\cobra\mit\__init__.py", line 2, in <module>
    from ._mit import Mit
  File "c:\workingdir\aci-learning-labs-code-samples\venv\lib\site-packages\acicobra-3.0_1k-py2.7.egg\cobra\mit\_mit.py", line 3, in <module>
    from .naming import Dn
  File "c:\workingdir\aci-learning-labs-code-samples\venv\lib\site-packages\acicobra-3.0_1k-py2.7.egg\cobra\mit\naming.py", line 4, in <module>
    from cobra.mit.meta import ClassLoader
  File "c:\workingdir\aci-learning-labs-code-samples\venv\lib\site-packages\acicobra-3.0_1k-py2.7.egg\cobra\mit\meta.py", line 82
    self.writeAccessMask = 0L
SyntaxError: invalid syntax
** I have followed the How To Setup Your Own Computer steps , and did notice some issues when I installed the acicobra and acimodel eggs, but both packages show up when I do a pip freeze so I thought it might be ok, but perhaps this is what is causing my error?
Below is what I got when installing the acicobra and acimodel eggs:
(venv) C:\workingdir\aci-learning-labs-code-samples\downloads>dir
Volume in drive C is OSDisk
Volume Serial Number is 52FA-BDC4
Directory of C:\workingdir\aci-learning-labs-code-samples\downloads
05/22/2018  02:29 PM    <DIR>          .
05/22/2018  02:29 PM    <DIR>          ..
05/22/2018  02:26 PM            92,412 acicobra-3.0_1k-py2.7.egg
05/22/2018  02:27 PM        98,170,955 acimodel-3.0_1k-py2.7.egg
               2 File(s)     98,263,367 bytes
               2 Dir(s)  128,041,852,928 bytes free
(venv) C:\workingdir\aci-learning-labs-code-samples\downloads>easy_install -Z acicobra-3.0_1k-py2.7.egg
Processing acicobra-3.0_1k-py2.7.egg
creating c:\workingdir\aci-learning-labs-code-samples\venv\lib\site-packages\acicobra-3.0_1k-py2.7.egg
Extracting acicobra-3.0_1k-py2.7.egg to c:\workingdir\aci-learning-labs-code-samples\venv\lib\site-packages
Adding acicobra 3.0-1k to easy-install.pth file
Installed c:\workingdir\aci-learning-labs-code-samples\venv\lib\site-packages\acicobra-3.0_1k-py2.7.egg
Processing dependencies for acicobra===3.0-1k
Searching for acicobra===3.0-1k
Reading https://pypi.org/simple/acicobra/
Couldn't find index page for 'acicobra' (maybe misspelled?)
Scanning index of all packages (this may take a while)
No local packages or working download links found for acicobra===3.0-1k
error: Could not find suitable distribution for Requirement.parse('acicobra===3.0-1k')
removing 'c:\workingdir\aci-learning-labs-code-samples\venv\lib\site-packages\acicobra-3.0_1k-py2.7.egg' (and everything under it)
acicobra 3.0-1k is already the active version in easy-install.pth
error: Could not find suitable distribution for Requirement.parse('acicobra')
(venv) C:\workingdir\aci-learning-labs-code-samples\downloads>easy_install -Z acimodel-3.0_1k-py2.7.egg
Processing acimodel-3.0_1k-py2.7.egg
creating c:\workingdir\aci-learning-labs-code-samples\venv\lib\site-packages\acimodel-3.0_1k-py2.7.egg
Extracting acimodel-3.0_1k-py2.7.egg to c:\workingdir\aci-learning-labs-code-samples\venv\lib\site-packages
Adding acimodel 3.0-1k to easy-install.pth file
Installed c:\workingdir\aci-learning-labs-code-samples\venv\lib\site-packages\acimodel-3.0_1k-py2.7.egg
Processing dependencies for acimodel===3.0-1k
Searching for acimodel===3.0-1k
Reading https://pypi.org/simple/acimodel/
Couldn't find index page for 'acimodel' (maybe misspelled?)
No local packages or working download links found for acimodel===3.0-1k
error: Could not find suitable distribution for Requirement.parse('acimodel===3.0-1k')
(venv) C:\workingdir\aci-learning-labs-code-samples\downloads>pip freeze
acicobra===3.0-1k
acimodel===3.0-1k
acitoolkit==0.4
arya==1.1.5
asn1crypto==0.24.0
certifi==2018.4.16
cffi==1.11.5
chardet==3.0.4
click==6.7
cryptography==2.2.2
deepdiff==3.3.0
dominate==2.3.1
flask==1.0.2
flask-admin==1.5.1
flask-bootstrap==3.3.7.1
flask-cors==3.0.4
flask-httpauth==3.2.3
flask-sqlalchemy==2.3.2
flask-wtf==0.14.2
gitdb2==2.0.3
gitpython==2.1.10
graphviz==0.8.3
idna==2.6
ipaddress==1.0.22
itsdangerous==0.24
jinja2==2.10
jsonpickle==0.9.6
jsonschema==2.6.0
markupsafe==1.0
py-radix==0.10.0
pycparser==2.18
pymysql==0.8.1
requests==2.18.4
six==1.11.0
smmap2==2.0.3
sqlalchemy==1.2.7
tabulate==0.8.2
urllib3==1.22
visitor==0.1.3
websocket-client==0.47.0
werkzeug==0.14.1
wtforms==2.1
Anyone who can help with this will be my new hero!!
-Pete
leo.espinosa
Frequent Visitor
Frequent Visitor
Hi Peter,
Did you solve the issue by yourself? i have the same problem except that i'm using macos.
Leo
Leo, what part are you stuck with please - can you share the error you are seeing? You can share this issue with us in the devnet webex team space for a quicker reply should you need https://developer.cisco.com/site/spark-chat/
Cheers!
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
i will post in the webex spark chat, but i got an error when i run the baseline.py script, same as the original post.
(py3-venv) Leos-MacBook-Pro:apic_fabric_setup leoespinosa$ python baseline.py
  File "/Users/leoespinosa/python-projects/003/aci-toolkit/aci-learning-labs-code-samples/apic_fabric_setup/startup_script.py", line 3, in <module>
  File "/Users/leoespinosa/py3-venv/lib/python3.7/site-packages/acicobra-3.0_1k-py2.7.egg/cobra/mit/__init__.py", line 2, in <module>
  File "/Users/leoespinosa/py3-venv/lib/python3.7/site-packages/acicobra-3.0_1k-py2.7.egg/cobra/mit/_mit.py", line 3, in <module>
  File "/Users/leoespinosa/py3-venv/lib/python3.7/site-packages/acicobra-3.0_1k-py2.7.egg/cobra/mit/naming.py", line 4, in <module>
  File "/Users/leoespinosa/py3-venv/lib/python3.7/site-packages/acicobra-3.0_1k-py2.7.egg/cobra/mit/meta.py", line 82
