APIC-EM 1.6 discovery API using POST request returns a 403
n.dambrosio
Frequent Visitor
Frequent Visitor
All,
I am having a problem running a python script that makes an API call to APIC-EM discoveries in order to build new discoveries to pull in new devices into APIC.
According the API documentation the a 403 error is this:
The server recognizes the authentication credentials, but the client is not authorized to perform this request.
The creds I am using are Internal users and set to Admin_Role with ALL.I don't see any other place add additional permissions to the users. Below is the script output from the python script.
https://pnp.ssg.petsmart.com/api/v1/discover
{'content-type': 'application/json', 'x-auth-token': 'ST-6621-fYkMLTtQRJTKddM7AWYm-cas'}
C:\Program Files (x86)\Python36-32\lib\site-packages\urllib3\connectionpool.py:858: InsecureRequestWarning: Unverified HTTPS request is being made. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.io/en/latest/advanced-usage.html#ssl-warnings
  InsecureRequestWarning)
Traceback (most recent call last):
  File "C:/Users/nd'ambrosio/Documents/Centralized Voice/PythonScript/windows/get-store-loc-hrs-audio-files-v2.py", line 242, in <module>
    startDiscovery(ip_range, controller, theTicket, store_num)
  File "C:/Users/nd'ambrosio/Documents/Centralized Voice/PythonScript/windows/get-store-loc-hrs-audio-files-v2.py", line 187, in startDiscovery
    raise Exception(response.status_code)
Exception: 403
<Response [403]>
Here is a screen shot taken from Postman that offer an odd CSRF error:
<!doctype html><html><head><meta http-equiv="content-type" content="text/html; charset=utf-8"><meta charset="utf-8" /><title> - APIC - Enterprise Module</title><meta name="viewport" content="width=device-width, initial-scale=1"><meta name="theme-color" content="#28cdc1"><link href="https://community.cisco.com/fonts/font-awesome-4.5.0/css/font-awesome.min.css" rel="stylesheet"><link rel="stylesheet" href="https://community.cisco.com/core/css/common.css" /><script type="text/javascript" src="/libs/socketio.js"></script><script type="text/javascript" src="/core/requirejsAdmin.js"></script><script type="text/javascript" src="/libs/apic-em.js"></script></head><body>
<!doctype html><html><head><meta charset="utf-8" /><title>Error</title></head><body><h1>invalid csrf token</h1><h2></h2><pre></pre></body></html></body>
</body></html><script type="text/javascript"  nonce="">
  window.appcontext = {
    uuid: ""
  window.GRAPEVINE_API_URL_PREFIX = "/apic/grapevine/api";
  window.API_URL_PREFIX = "/apic/api/v1";
  window.API_URL_PREFIX_V0 = "/apic/api/v0";
  window.CSRF = "";
</script>
aradford
Hi Nicholas,
did you mean to use https://pnp.ssg.petsmart.com/api/v1/discovery (with a "y")?
The correct URL is '/discovery' not '/discover'
Adam
aradford
Hi Nicholas,
Adam
Oh my goodness. i have been staring at code for a week now and even rebooted my APIC server. Yup, that was it. I must have left the "y" off when i copied the URL.
Thank you so very much.
{'content-type': 'application/json', 'x-auth-token': 'ST-8334-BeSb0pvrb5rFFUg1PcaS-cas'}
<Response [202]>
Discovery Task Successfully Initiated
Process finished with exit code 0
Can you comment again so that i can click "correct answer".
Hi Nicholas,
we have all done that before.  The forums are here to help.
Glad it was a quick fix.
I actually recognised the payload from Postman from my <many> fat fingerings of URL...
Adam
