APIC-EM API reference Documentation in detail
htoyota
Hi expert,
Now, SI partner and I are struggling hard against making a coceptual demo application of APIC-EM using Devnet Sandbox.
Could you give me APIC-EM API reference Documentation in detail?
I want to know Request/Response Payload Parameters(Type, Attribute Name and Description) as like as PI.
PI API detailed reference on Cisco.com
http://www.cisco.com/c/dam/en/us/td/docs/net_mgmt/prime/infrastructure/3-0/api_reference/guide/cpi_apiref30.zip
PI API detailed reference on Devnet
https://developer.cisco.com/site/prime-infrastructure/documents/api-reference/tutorial/
htoyota
Geevarghese Cheria
   Did you had any chance to go though the following url
   Cisco DevNet: Coding 101 Tutorial
  Also Regarding the API Documentation request to refer
https://developer.cisco.com/site/apic-em/documents/api-reference/
Thanks and Regards,
Geevarghese
Thank you for quick reply.
I've already refered these API Documentation.
Cisco DevNet: APIC Enterprise Module (EM) - API Reference Guide
I want to know parameter discription.
For example, what does "networkUser" mean in POST/Policy?
htoyota
Better API documentation will be available when the GA release happens.  I had some similar struggles integrating with APIC-EM.  What I found useful was to use the GET method to try and understand what was there in terms of property values, then use similar values when doing POST/PUT.
What type of application are you wanting to build?  Perhaps we can offer some specific hints.
