APIC-EM discovery using AD/RADIUS credentials
vantipov
Level 3
Level 3
I installed APIC-EM and was trying to run device discovery.  We use Active Directory RADIUS for auth so for user name I have to enter: domain\user. APIC-EM interface complains that I am using an illegal char \.  I have tried it using '\' and "\", also tried using user@domain still get an error.  Any thoughts?
Ok, it's a bug. Wii get it fixed.
Thanks for finding this.
5 Replies 5
yawming
Please please describe where you saw the error and exactly error message ?
Is the following step you were trying to do ?
I think the screen you are showing is in Discovery and then CLI credentials.  I was trying to add a global CLI Credentials under Settings (top right corner) -> CLI Credentials.Screen Shot 2016-04-26 at 11.22.52.png
Thanks, I see the same. I will get some help.
You must be with Cisco.  Thanks for taking care of this.
