APIC-EM PNP very chatty after provisioning
zlantz
Level 4
Level 4
We have been slowly implementing our PNP solution into our environment and now that we have a few deployments in production, I started to notice how chatty the switches that I have provisioned with PNP are after provisioning. I have failed broadcast tftp attempts that just fill up logs and make it really difficult to actually see what the log is saying on the switch. Most of the time, I end up going and pulling the historical logs from our syslog server because these messages just exceed the logging buffer.
Jan  2 2017 07:39:37.830 EST: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/network-confg) failed (TEST-3650-SW-STACK-2)
Jan  2 2017 07:40:15.832 EST: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/cisconet.cfg) failed (TEST-3650-SW-STACK-2)
Jan  2 2017 07:40:51.770 EST: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/test-3650-sw-stack-confg) failed (TEST-3650-SW-STACK-2)
Jan  2 2017 07:41:29.781 EST: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/test-365.cfg) failed (TEST-3650-SW-STACK-2)
Jan  2 2017 07:47:20.405 EST: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/network-confg) failed
Jan  2 2017 07:47:58.407 EST: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/cisconet.cfg) failed
Jan  2 2017 07:48:34.448 EST: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/test-3650-sw-stack-confg) failed
We are using DHCP to facilitate PNP, but we are also using Microsoft's DHCP. We have global rules in place for DNS and TFTP. Because I ran into issues during testing, I made local rules in the scope I was using for PNP to point DNS and TFTP at my APIC-EM IP.
Anyone else seeing similar results?
aradford
Hi Zak,
you could include the "no service config"
as part of the configuration you push.
(you can also apply it post deployment to your existing switches)
This will turn off the tftp attempts.
Adam
aradford
Hi Zak,
Adam
