Controller fails to start services after upgarde
mehdi.rashidi
After upgrading to the latest version, the controller fails to start services successfully. I listed running services :
$ grapectl status
[sudo] password for grapevine:
grapevine_capacity_manager              RUNNING   pid 32743, uptime 1:44:24
grapevine_capacity_manager_lxc_plugin   RUNNING   pid 32737, uptime 1:44:24
grapevine_cassandra                     RUNNING   pid 32210, uptime 1:44:41
grapevine_client                        RUNNING   pid 32207, uptime 1:44:41
grapevine_coordinator_service           RUNNING   pid 388, uptime 1:44:21
grapevine_dlx_service                   RUNNING   pid 32212, uptime 1:44:41
grapevine_log_collector                 RUNNING   pid 32222, uptime 1:44:41
grapevine_root                          RUNNING   pid 32211, uptime 1:44:41
grapevine_supervisor_event_listener     RUNNING   pid 32206, uptime 1:44:41
grapevine_ui                            RUNNING   pid 32208, uptime 1:44:41
reverse-proxy=5.0.0.4270                RUNNING   pid 9167, uptime 1:38:00
router=5.0.0.4270                       RUNNING   pid 9168, uptime 1:38:00
and then did ./bin/reset_grapevine but it stopped at below:
2017-05-03 14:09:12,192 | Growing services (this can take several minutes). Please wait...
2017-05-03 14:09:12,312 |    Running [12/37]: reverse-proxy postgres cas-service grapevine node-ui rabbitmq grapevine-log-collector election-service router grapevine-coordinator-service rbac-service cassandra
2017-05-03 14:11:23,345 |    Running [13/37]: ipgeo-service
2017-05-03 14:12:23,924 |    Running [14/37]: file-service
2017-05-03 14:15:05,597 |    Running [15/37]: ip-pool-manager-service
2017-05-03 14:16:16,286 |    Running [16/37]: app-vis-policy-programmer-service
2017-05-03 14:16:51,661 |    Running [17/37]: pnp-service
2017-05-03 14:18:07,442 |    Running [19/37]: nbar-policy-programmer-service access-policy-programmer-service
2017-05-03 14:19:08,031 |    Running [20/37]: qos-policy-programmer-service
2017-05-03 14:19:18,137 |    Running [21/37]: visibility-service
2017-05-03 14:19:48,429 |    Running [22/37]: apic-em-pki-broker-service
2017-05-03 14:19:58,526 |    Running [24/37]: apic-em-jboss-ejbca pfr-policy-programmer-service
2017-05-03 14:20:59,123 |    Running [25/37]: grouping-service
2017-05-03 14:21:09,227 |    Running [26/37]: qos-lan-policy-programmer-service
2017-05-03 14:21:39,535 |    Running [27/37]: apic-em-event-service
2017-05-03 14:24:21,155 |    Running [28/37]: network-poller-service
2017-05-03 14:26:27,395 |    Running [29/37]: apic-em-inventory-manager-service
2017-05-03 14:26:47,605 |    Running [30/37]: apic-em-network-programmer-service
2017-05-03 15:09:13,564 | [grow_all_services:1159] Timeout of 3600 seconds has been exceeded while growing services. The following services are not yet in RUNNING state: scheduler-service, identity-manager-pxgrid-service, policy-manager-service, task-service, topology-service, policy-analysis-service, telemetry-service
2017-05-03 15:09:13,565 | Config wizard completed with errors
Any idea how I can resolve this issue?
aradford I resolved the issue by installing the latest upgrade 1.4.2
7 Replies 7
aradford
This is usually an indication that the DiskIO is not good enough.
I assume you have enough RAM and vcpu?
Can you run the following command on the grapevine console:
dd if=/dev/zero of=/tmp/foo bs=1M count=512 conv=fdatasync
That will give you an indication of the disk IO.
You should see output similar to this
512+0 records in
512+0 records out
536870912 bytes (537 MB) copied, 23.7006 s, 22.7 MB/s
DiskIO looks fine:
$ dd if=/dev/zero of=/tmp/foo bs=1M count=512 conv=fdatasync
512+0 records in
512+0 records out
536870912 bytes (537 MB) copied, 2.40962 s, 223 MB/s
(grapevine)
vCPU: 8
Memory: 64G
Very strange.  Specs looked fine.
Have you also upgraded the IWAN app too
Adam
Yes I did although it wasn't complaining about the old version 1.4.0.417
Do you have a case open regarding this issue?
I'm using the free version with no official support so no I didn't open a ticket for this.
