CUCM and APIC
martin_oyarzun
Visitor
Hola,
I enabled Dynamic QoS but interaction between CUCM System version: 9.1.2.13900-10 and APIC is not been reflected changing configuration on Switch when I started a call.
How can we verify API is working between CUCM and APIC?.
Martín.
aradford
You need 11.5u1 for this to work.
Older versions of cucm had an older version of the API.
Adam
Sent from my iPhone
yawming
May need  CUCM 11.5.su1 or higher ?
aradford
Adam
Sent from my iPhone
martin_oyarzun
Visitor
Thank you very much to all of you!!!
