06-20-2017 08:44 PM - edited 03-01-2019 04:38 AM
Hi There,
We deployed a couple of Cisco C3560CX switch via APIC-EM P&P a couple of weeks ago, recently those switches status became 'unclaimed' after I upgrade APIC-EM from 1.3.2.37 to 1.4.3.1009. Please check the event of one of the switch below: may i know why? how can we fix it?
Thanks in advance.
| 2017-06-21 10:23:45 (W. Australia Standard Time) | Device authentication status has changed to Unauthenticated(SUDI feature not supported by device) |
| 2017-06-20 17:22:01 (W. Australia Standard Time) | Device authentication status has changed to Unauthenticated(SUDI feature not supported by device) |
| 2017-06-20 14:10:59 (W. Australia Standard Time) | UNCLAIMED |
| 2017-06-20 14:09:56 (W. Australia Standard Time) | Received new work request from Agent while expecting work response. Retrying operation RETRIEVING_IP_ADDRESSES_PRE_CONFIG |
| 2017-06-20 14:08:14 (W. Australia Standard Time) | Received new work request from Agent while expecting work response. Retrying operation FILESYSTEM_INFO_REQUESTED |
| 2017-06-20 14:06:32 (W. Australia Standard Time) | Device authentication status has changed to Unauthenticated(SUDI feature not supported by device) |
| 2017-06-20 14:06:31 (W. Australia Standard Time) | Device first contact |
| 2017-06-14 14:06:05 (W. Australia Standard Time) | Device authentication status has changed to Unauthenticated(SUDI feature not supported by device) |
| 2017-04-23 11:19:34 (W. Australia Standard Time) | Device was successfully deployed!! |
| 2017-04-23 11:18:13 (W. Australia Standard Time) | Save startup Configuration was performed successfully |
06-23-2017 10:19 AM
Not sure how to go about fixing it, it looks like the device status in the DB was somehow reset during the upgrade of APIC-EM.
Is it necessary that the device show up in the PnP screens at all? If not I would think you can just delete it and do a regular discovery to manage it. Would that meet your needs?
06-28-2017 07:47 PM
Thanks David.
Unfortunately we still got same issue after rediscovery. Please check history info from one of the equipment. Anyone can help?
2017-06-28 09:01:01 (W. Australia Standard Time)
UNCLAIMED
2017-06-28 08:57:42 (W. Australia Standard Time)
2017-06-28 08:55:59 (W. Australia Standard Time)
2017-06-28 08:55:58 (W. Australia Standard Time)
2017-06-28 08:55:00 (W. Australia Standard Time)
Device was Un-Ignored and moved from Ignored State to Unclaimed state
2017-06-28 06:54:44 (W. Australia Standard Time)
Device was moved to Ignored state
2017-06-21 14:40:08 (W. Australia Standard Time)
UNCLAIMED
2017-06-21 14:36:49 (W. Australia Standard Time)
2017-06-21 14:35:05 (W. Australia Standard Time)
2017-06-21 14:35:04 (W. Australia Standard Time)
Cheers,
Bright
06-28-2017 09:41 PM
So is the 3560 just sitting there with no configuration now or does it have the configuration that was pushed from APIC-EM 1.3 when it worked the first time?
06-28-2017 09:45 PM
They all got the configuration that was pushed from APIC-EM 1.3 and worked very well.
They are still online and doing their job, but APIC-EM 1.4 keep saying they are unclaimed ☺
06-28-2017 09:49 PM
I am guessing at this point, but I think the database, for whatever reason, lost that it was already provisioned, and since it is already provisioned, it is not going through the process that it normally would. Is there any issue with just deleting it from the PnP project? At least that way you son't have to stare at it saying Unclaimed 🙂
06-28-2017 10:11 PM
The problem is that it will come back after second every time when I deleted them from PnP project.
I just worried some guys accidently claim those equipment and break the switches. Now I have to lockdown all other users access to APIC-EM just in case. It’s very annoyed.
Cheers,
Bright
06-28-2017 10:22 PM
Ahhh, ok, yeah I get it now. Yeah, I would bet that the database is corrupt, which I saw after my upgrade from1.3 to 1.4 as well. I did a reset grapevine to fix it, but that can be super annoying. Maybe open a TAC case and if they have any tricks up their sleeve?
06-28-2017 10:27 PM
LOL, I thought you are TAC engineer.
If I can’t get answer from here, I will log a TAC.
Thanks mate.
06-29-2017 05:03 AM
Hi Bright,
did you try to "ignore" the device in the unclaimed list?
Adam
