Does Cisco plan to include python librairy "requests" in Guestshell
Jerems
Does anyone know if Cisco plan to provide with the python "requests" librairy in the incoming release of the Guestshell ?
Thanks in advance,
Jerems
2 Accepted Solutions
Marcel Zehnder
Hi Jerems
You can install packages via pip in guestshell:
[guestshell@guestshell ~]$ sudo pip3 install requests
WARNING: Running pip install with root privileges is generally not a good idea. Try `pip3 install --user` instead.
https://files.pythonhosted.org/packages/2d/61/08076519c80041bc0ffa1a8af0cbd3bf3e
    100% |################################| 71kB 1.8MB/s
<SNIP>
[guestshell@guestshell ~]$ python3
Python 3.6.8 (default, Dec 22 2020, 19:04:08)
[GCC 8.4.1 20200928 (Red Hat 8.4.1-1)] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import requests
Jerems
Hello dear community,
If you plan to provide with Internet access to your Guestshell container please follow this procedure :
Configure interface VirtualPortGroup0 (GW for the container):
 ip nat inside
 no mop enabled
 no mop sysid
Configure interface GigabitEthernet0/0/0.13 (My "WAN" interface"):
 encapsulation dot1Q 13
 ip address 192.168.13.2 255.255.255.252
 ip nat outside
 Configure NAT :
ip nat inside source list GUESTSHELL-NAT-ACL interface GigabitEthernet0/0/0.13 overload
ip access-list extended GUESTSHELL-NAT-ACL
 10 permit ip 192.168.1.0 0.0.0.255 any
And the app-hosting part:
app-hosting appid guestshell
 app-vnic gateway0 virtualportgroup 0 guest-interface 0
  guest-ipaddress 192.168.1.2 netmask 255.255.255.0
 app-default-gateway 192.168.1.1 guest-interface 0
 name-server0 192.168.0.252
 name-server1 192.168.0.250
6 Replies 6
Marcel Zehnder
Hi Jerems
<SNIP>
>>> import requests
Jerems
To do so i need to provide with internet access to guestshell which seems impossible at the moment.
My guestshell runs on top of a Cisco ISR1111 version 16.12.04.
By the way, let me double check with google if i can find out a way to fix this.
Yes, either internet access or you host your own repo somewhere accessible by the router (https://packaging.python.org/en/latest/guides/hosting-your-own-index/)
Jerems
I found a fix to allow the guestshell to access Internet :
Thanks to this article :
https://blog.wimwauters.com/networkprogrammability/2020-06-08_guestshell_onbox/
Thank you again
Jerems
 ip nat inside
 no mop enabled
 no mop sysid
 description Lien vers Jeyniper01 - vlan Internet
 ip nat outside
 Configure NAT :
Jerems
 ip nat inside
 no mop enabled
 no mop sysid
 ip nat outside
 Configure NAT :
