EasyQOS with subinterfaces
arikgelman
Level 3
Level 3
I am trying to apply QOS policy with EasyQOS on Cisco ASR-1001X router. On this router I have interface with sub-interfaces and different QOS policy on each sub-interface. I added the description #WAN#50M#SPP1#, #WAN#45M#SPP1# etc on every sub-interface but there is no special policy added on the sub-interfaces.
Thanks is advance.
Arik
Hi Arik,
This has been filed as a bug:
EasyQoS 1.3: CSCvb09687: Service provider profile is not supported on sub-interfaces
We'll make sure it gets fixed by the next release (1.4 ~ December).
Thanks raising visibility on this missing functionality.
-tim
12 Replies 12
szigeti
Hi Arik,
What is the policy that is added to the sub-interfaces? e.g. the sub-int tagged with: #WAN#50M#SPP1# ?
Can you post the configs?
TIA.
-tim
Thank you very much for the fast response.
I added "#WAN#50M#SPP1#" and "#WAN#45M#SPP1# to the description of the sub-interfaces, for example:
interfaces gigabitethernet 0/0/0
interfaces gigabitethernet 0/0/0.10
description Main-Interface-To-Site-10 #WAN#50M#SPP1#
interfaces gigabitethernet 0/0/0.20
description Main-Interface-To-Site-20 #WAN#45M#SPP1#
When I applied the policy with EasyQOS, the policy that was attached to the main interface (with the sub-interfaces) is the same policy as the policy attached to the other main interfaces (without sub-interfaces) on the router, for example:
service-policy output prm-dscp#QUEUING_OUT
interfaces gigabitethernet 0/0/1
interfaces gigabitethernet 0/0/2
There was no special policy attached to the sub-interfaces with the special description.
I am out of office so I can't add the full config, I will try to update as soon as possible, Hope the information here will help.
Thanks again
Arik
Hi Arik,
-tim
Hi Arik,
Is the behavior you are looking for something like the following:
interface GigabitEthernet0/0/5
no ip address
shutdown
negotiation auto
plim qos input map ip dscp-based
plim qos input map ip dscp  32  40  queue strict-priority
interface GigabitEthernet0/0/5.100
service-policy output prm-dscp#EQ_SPP1-4Class#shape#50.0
interface GigabitEthernet0/0/5.200
service-policy output prm-dscp#EQ_SPP1-4Class#shape#45.0
Here's an example of the top level of the policy-maps.
policy-map prm-dscp#EQ_SPP1-4Class#shape#45.0
class class-default
  shape average 45000000
   service-policy prm-dscp#EQ_SPP1-4Class
policy-map prm-dscp#EQ_SPP1-4Class#shape#50.0
class class-default
  shape average 50000000
Each sub-interface has a hierarchical policy with a shaper and a child policy (not shown).
Let me know if that is the configuration you are trying to support.
Yes, this is what I was looking for.
Hi Arik,
Can you share some additional information about the setup? We are in the process of adding support for this, but would like to learn a bit more about your use case. Please send "make-a-wish" request and we can connect offline...
-Ramit
Dear Ramit
Sorry for the late response and thank you for your help, Here are some use cases that from what I have seen EasyQOS does not support.
Multi GRE tunnels from same source interface – In this scenario I have one IP address from the hub router that is connected to the SP, The spokes routers are also connected via the same SP with one interface. There are two GRE tunnels going from the hub router, one to each spoke exiting from the same physical interface G0/0. In this case I am adding the special description ("#WAN#XXM#SPPY#") on the GRE tunnels.
In this use case EasyQOS need to add special QOS policy to the GRE tunnels and not to add any QOS policy to the physical interface the GRE tunnels are exiting from (Doing that will lead to an error)
Multi GRE from different sub-interface – this scenario is the one I explained at the beginning of the thread, In this case the hub router have two sub-interfaces, one to each spoke. The GRE tunnel exit to each spoke via the sub-interface. The special description ("#WAN#XXM#SPPY#") is added this time to the sub-interface and EasyQOS need to implement the policy as described at the beginning of the thread.
Thanks for all your help
Arik
Hi Arik,
Thanks for the information, this is quite helpful. Do you also see a use case where you might have a shaper on the physical interface (no queueing policy, just a shaper), which is less than the sum of the shaped rates under all the sub-interfaces of this physical interface? This would allow you to oversubscribe a bit, assuming not all sub-interfaces operate at peak load all the time.
Ramit
In my case the shaping is per GRE in the first use case, or on the sub-interface in the second use case. I am not using shaping on the main interface but I always make sure that the maximum bandwidth of all spokes sites together will not be more than the physical interface maximum bandwidth.
Hi Arik,
Just for clarity, is this a DMVPN configuration or non-DMVPN....or potentially either?
Thanks.
This is non-DMVPN, only GRE tunnels
Will it be supported in logical interfaces too? for example GRE tunnels?
