How can I change IP of APIC-EM
Rasika Nayanajith
I have installed APIC-EM 1.2. Now I want to change the IP address of this server ? What is the procedure for this
I hope I can do this without re-installation
Rasika
rnaggi
As far as i remember , You will have to run the config_wizard from the cli of the APIC-EM cluster.
Steps:
1. SSH using grapevine user to APIC-EM
2. Run ./Config_wizard
Note: I will let others comment too. Meanwhile i will try to find the answer
8 Replies 8
rnaggi
Steps:
Hi Rohan,
Thanks for your response.
I am getting the following error when I run config_wizard as the grapevine user. I have also tried running the command as root, but the command is not found.
Traceback (most recent call last):
                                    File "/opt/cisco/grapevine/bin/grapevine_config_wizard_lxc", line 9, in <module>
        load_entry_point('grapevine-config-wizard==1.2.0.11539.dev555-g6906b29', 'console_scripts', 'grapevine_config_wizard_lxc')()
        File "/opt/cisco/grapevine/local/lib/python2.7/site-packages/grapevine_config_wizard/appliance/ConfigWizard.py", line 95, in main_func
        context = GrapevineContext(responses)
                           File "/opt/cisco/grapevine/local/lib/python2.7/site-packages/grapevine_config_wizard/appliance/GrapevineContext.py", line 335, in __init__
                                     self._init_curses()
                                                          File "/opt/cisco/grapevine/local/lib/python2.7/site-packages/grapevine_config_wizard/appliance/GrapevineContext.py", line 886, in _init_curses
        curses.init_pair(Colors.WHITE_ON_BLUE, curses.COLOR_WHITE, curses.COLOR_BLUE)
                 _curses.error: init_pair() returned ERR
                                                        (grapevine)
[Mon Jul 04 07:02:13 UTC] grapevine@10.128.*.* (grapevine-root-1) ~
Pls let me know if you found exact procedure
Rasika
how are you running this?  from an SSH session, or from VM console?
SSH to APIC-EM as grapevine user.
Not via VM console (tried that too, but did not work, even that command did not run via console)
Rasika
Hi All,
I found out the above error occurred only on SecureCRT. When I used Putty everything worked normally.
Thanks for the help
Rasika
great news.  It looks like an issue with the terminal emulation.
Thanks for the update
BTW, what terminal emulation are you using for SecureCRT?  xterm?
Geevarghese Cheria
   Adding comments to Rohan's Reply As you are planning to change the host ip address for APIC-EM  you need to first ensure that the DNS and NTP servers are reachable before you run the configuration wizard and whenever a Cisco APIC-EM host reboots in the deployment. Also If the external IP address changes for your controller for any reason, then you need to re-import a new certificate with the changed or new IP address.
Please refer the deployment guide for more details.
http://www.cisco.com/c/en/us/td/docs/cloud-systems-management/application-policy-infrastructure-controller-enterprise-module/1-2-x/deploy-guide/b_apic_em_deploy_guide_v_1-2-x.html
Thanks and Regards,
Geevarghese
