Controllers
Community space to connect, share knowledge, and seek guidance on network controllers and related topics
From the v2 active devices endpoint documentation listed on https://developer.cisco.com/docs/cisco-spaces-location/v2/v2devices/ I notice that compared to the CMX Location API, properties such as username, IP address and the SSID the device is associ...
empty by • Community Member
  • 467 Views
  • 0 replies
Hello all,I am working on utilizing Terraform to manage our 9800 WLCs.So far everything with the ios-xe provider has worked well, though for most of our wireless settings, we have to use the restconf module from the provider to accomplish the intende...
hexabyte8 by • Community Member
  • 2118 Views
  • 3 replies
I'm trying to implement secret strings in order to avoid plain text passwords in my yaml files.All pyats documentation points me to make changes to the "pyats.conf" file. However, I cannot find such a file.Any idea where this could be? I've used ever...
Hello everyone, is there a possibility to use the genie parser on output saved in text files?The issue is that that it is not possible to install pyATS or genie on the machine where I can access the devices. What I can do is get the output of "show i...
We want you to interact with SONiC on the Cisco 8000 router.  You’ll see in action, a 3-stage Clos topology bring-up and deploy a reliable network that is optimised for latency. Click here to explore the sandbox : https://devnetsandbox.cisco.com/RM/D...
annag by • Cisco Employee
  • 3852 Views
  • 5 replies
  • 10 Helpful votes
I am trying to set up pyats in a virtual environment. When I run:pip install --trusted-host=pypi.org --trusted-host=files.pythonhosted.org pyats[full]I get this error:ERROR: Could not find a version that satisfies the requirement pyats[full] (from ve...
Hi,It will be very helpful if someone can help with a script (preferably Python) using which I can change/update the hostnames of multiple Cisco devices instead of doing it one by one manually.I already have the hostname configured just need to updat...
Hello,I tried the following on Cisco DevNet Sandbox to add a network and received the following error: $ python3 Meraki_Post_Network2.pyTraceback (most recent call last):  File "Meraki_Post_Network2.py", line 11, in <module>    requests.post ("/base_...
Netmart by • Level 7
  • 2107 Views
  • 3 replies
