Issue found. Where to submit it
bavo
Level 2
Level 2
I found some thing that looks like an issue with the APIC-EM software pack.
Where can i summit this issue?
Zach Seils
Level 11
Level 11
Hi Bavo,
Thanks for reaching out to the community. Can you describe the issue?
Zach
Hi Seils,
I`m gonna try to explane.
Sins a short while we are using APIC-EM. Now we are using the “Path Trace” feature in APIC-EM. we found what seems to be an error.
When i use the "path trace" feature. I enter the source and destination host. When i hit "start trace"
The result is unfortunately not correct somehow.  The result is al follow:
Host------Switch01----Router01----Switch02----Router01---Switch02----Router01-----Switch02----?
The error message is "unable to find path, showing partial path. Loop detected at device Router01"
Router01 is part of a Layer 2 EVPN. More locations can be seen with CDP commando.
But if i login on Router01 and i do a "sh ip route [destination ip]" is shows me the preferred path and egress interface.
The ergress interface is correct, but the next hop router is wrong.
This is how i should be i think:
Host-----Switch01----Router01----Router02----Router03----Switch03----Host
If i use other source and destination addresses the same problem keeps occurring.
Is there a way to debug the trace?
If you need more information pleas let me know.
I hop you can help me with this. Thanks in advanced
Greetings
Bavo
Can you run ‘rca’ from the APIC-EM Linux shell and upload the file that’s created? Please email me directly @ [email protected] <mailto:[email protected]> for the upload location.
Zach
