Issue with ACI MSO (Multi-site Ochestrator) : API Call to create a new EPG using PATCH method.
shamax_1983
Level 3
Level 3
Hi Guys,
I've been trying to get this to work for few days now but couldn't figure out the issue.
I can successfully create VRFs, BDs, etc using the API (PATCH + add method) in the MSO.   Please note that I want to use the PATCH method so I don't have to include the entire structure in each call (which is massive).
I am using the MSO version 2.2.3j
When I run the following (using Postman),
"op": "add",
"path": "/templates/temp1/anps/testANP2/epgs/-",
"value": {
    "name": "myEPG",
    "displayName": "MY EPG",
    "contractRelationships": [],
    "subnets": [],
    "uSegEpg": false,
    "uSegAttrs": [],
    "intraEpg": "unenforced",
    "proxyArp": false,
    "preferredGroup": false,
    "selectors": [],
    "bdRef": "/schemas/603ed1ed340000e38f7244dd/templates/temp1/bds/myBD"
I keep getting the error below.
    "code": 400,
    "message": "Bad Request: (2)(1)/epgs(0)/schemaId error.path.missing"
Can someone point out what is missing here?  Appreciate your input.
robin.martinez
Did you ever get anywhere with this? I'm essentially having the same issue just trying to add a BD although the error is slightly different.
It happens using Postman or the API Explorer in the MSO GUI.
    "code": 400,
    "message": "Bad Request: (0)(3)/schemaId error.path.missing"
No, I couldn't get it working with EPG creation. Did you get it working for the EPG creaion?
In any case, I did get the BD creation fine using the following.
"op": "add",
"path": "/templates/Template1/bds/-",
"value": {
"displayName" : "My BD",
"name" : "myBD",
"subnets" : [],
"vrfRef": {
    "schemaId" : "603ed1ed324000e38f7244dd",
    "templateName": "Template1",
    "vrfName": "YourTestVRF"
"intersiteBumTrafficAllow": true,
"optimizeWanBandwidth": true,
"l2Stretch": true
Thanks this actually helped.  Looks like I needed to use that broken out format for the vrfRef for the Anp and Bd References.  I'm using MSO 3.3.1 on Nexus Dashboard 2.0.2 deployed in Vmware.  Next I need to try and add the rest of the information for the BD and EPGs, and attach the site specific interfaces.
I was able to make the BD first then the EPG using a similar format to this using postman.
Patch -> https://{{MSO}}:/api/v1/schemas/{{schemaID}}?enableVersionCheck=false&validate=true
        "op":"add",
        "path":"/templates/Template1/anps/{{anp}}/epgs/-",
        "value":{
            "name": "NutanixTest3",
            "displayName": "NutanixTest3",
            "anpRef":{
                "schemaId": "{{schemaID}}",
                "anpName": "{{anp}}"
            "vrfRef": {
                "vrfName": "vrf_spanned"
            "bdRef":{
                "bdName": "NutanixTest3"
