Cobra SDK fails to import into python script
Wade Patterson
I'm trying to call modules from the cobra sdk into a python script but it keeps failing to load each time.  What I've done:
- downloaded both .whl files from the APIC (acicobra and acimodel)
- pip installed both .whl files into a python 3.8 virtual environment
- performed "run and debug" in VSC
Here is a screenshot of the failure during debug:
I know that acicobra and acimodel is installed:
Not really sure why the script can't find the module.  Any help is greatly appreciated!!!! 
kkhlebop
I don't see the error message in your post, perhaps you are referring to vscode's yellow squiggle underlines that refer to not found modules, so I will investigate that and try to recreate this issue.
I tried to recreate the issue with python 3.8.3 using these steps. In my case running python from the shell worked (which pointed at my virtual environment). However, when I opened with vscode, I had the same issue as you. This was, I found out, because vscode was trying to use another python environment and not the virtualenv.
My suggestion is to look into how to get vscode to use the virtualenv instead of its default python paths. I might be wrong, but I don't think running source bin/activate is enough to get the rest of the IDE to use the same python version.
Here are the steps I took:
pyenv local 3.8.3    # switch to python 3.8.3
mkdir apic
cd apic
python -V; pip -V    # to confirm I am using correct version of python 3.8.3
python -m venv venv
source venv/bin/activate
python -V; pip -V    # to confirm that I am using the python 3.8.3 from the virtualenv
cp Downloads/aci* .    # copy the apic sdk files to local dir (i got these from https://developer.cisco.com/docs/aci/#!cobra-sdk-downloads/aci-learning-labs )
pip install acicobra-4.2_3h-py2.py3-none-any.whl    # install acicobra
pip install acimodel-4.2_3h-py2.py3-none-any.whl    # install acimodel
git clone https://github.com/CiscoDevNet/aci-learning-labs-code-samples
cd aci-learning-labs-code-samples/apic_fabric_setup    # go to the directory where startup file is at
code . # open vscode. then I saw the same marks - also trying to run the code from vscode fails at the import
python startup_script.py  # this code gets past the imports and fails at connection as I didn't edit my code's connection parms
### output: ###
❯ python startup_script.py
Baselining APIC Simulator for Learning Labs
Setting up Fabric Nodes
Traceback (most recent call last):
  File "startup_script.py", line 30, in <module>
    md.login()
  File "/Users/kkhlebop/Dropbox/src/apic/venv/lib/python3.8/site-packages/cobra/mit/access.py", line 32, in login
    self._accessImpl.login()
  File "/Users/kkhlebop/Dropbox/src/apic/venv/lib/python3.8/site-packages/cobra/internal/rest/accessimpl.py", line 128, in login
    loginHandler.login(self._session)
  File "/Users/kkhlebop/Dropbox/src/apic/venv/lib/python3.8/site-packages/cobra/internal/rest/accessimpl.py", line 81, in login
    session._parseResponse(rsp)
  File "/Users/kkhlebop/Dropbox/src/apic/venv/lib/python3.8/site-packages/cobra/mit/session.py", line 179, in _parseResponse
    rsp.raise_for_status()
  File "/Users/kkhlebop/Dropbox/src/apic/venv/lib/python3.8/site-packages/requests/models.py", line 953, in raise_for_status
    raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 401 Client Error: Unauthorized for url: https://sandboxapicdc.cisco.com/api/aaaLogin.json
Here are my pip shows:
❯ pip show acimodel
Version: 4.2-3h
Summary: The Management Information Tree
Home-page: UNKNOWN
Author: Cisco Systems
Author-email: [email protected]
License: Cisco Systems Inc. (Copyright 2014)
Location: /Users/kkhlebop/Dropbox/src/apic/venv/lib/python3.8/site-packages
Requires: acicobra
Required-by:
❯ pip show acicobra
Version: 4.2-3h
Summary: Access API for the Management Information Tree
Home-page: UNKNOWN
License: Cisco Systems Inc. (Copyright 2013 - 2014)
Requires: future, ply, requests, setuptools
Required-by: acimodel
Below is a screenshot showing the python paths and pip show for both modules - as you can see its pointing at wrong path and can't find it. If I do the source bin/activate, it will work for the terminal, but the rest of the IDE will not follow with - however I know there is a way, just need to look for vscode documentation or forums on how to get VSCODE working with virtualenv.
kkhlebop
mkdir apic
cd apic
python -m venv venv
### output: ###
    md.login()
❯ pip show acimodel
Version: 4.2-3h
Home-page: UNKNOWN
Requires: acicobra
Required-by:
❯ pip show acicobra
Version: 4.2-3h
Home-page: UNKNOWN
Wade Patterson
Very helpful and thank you for the detailed post @kkhlebop !!!  The only thing I have to add is that I needed to change the url/username/password in the credentials.py script to a different ACI environment.
