Issue With Adding SNMP RO String
adammmorton
Level 2
Level 2
I'm trying to add a RO community string for discovery in the APIC-EM controller and get the following error:
Unable to add Read Community; 400:undefinded
My community string has a @ < > and ! character in it.  I'm assuming this is causing the issue as I can put numbers and letters only in there and it works.  We have several hundred devices that use this community string and I would rather not have to change it one every device we have.  Is there a way to fix this?  I'm running version 1.3.3.126
aradford
Hi Adam,
that will be the input validation to prevent XSS attacks.
It is the "<" character that is a problem.
Not sure if there is a work around to escape it.
Adam
One possible workaround would be to define a new SNMP string on APIC-EM, then use the admin->settings->Device Controllability -> SNMP Autoconfig option to try to provision the new credential?
Adam
