Need suggestion for PNP solution
JPvisltgb
Level 4
Level 4
I need some suggestions for PnP solution. I have many branch offices.
Branch office it is simple topology Router Gi0/1 ---> Gi0/49 Switch.
Router is connected to HQ through MPLS network. DHCP server is in the HQ.
So we are planning to start PnP solution using Apic-EM for all network hardware in branch office.
Scenario:
First part:
Empty router is connected to  ISP CPE router. CPE router is relaying DHCP requests from router to central DHCP. Router getting  DHCP configuration. After that it is connecting to APIC-EM using url pnpserver.domain.com and getting all config.
Second part:
After router succesfully provisioned it become "router-on-stick". It have several subinterfaces with tagged traffic (Management, Users and Phones)
And here we have a problem:
Empty switch which is connected to router by default is trying to get DHCP to Vlan1 but router doesn't have untagged vlan on its link anymore.
We came up with one solution:
We created additional network (and new DHCP scope) for switch deployment. On Branch router on Gi0/1 we configured  IP address  and ip helper to our DHCP for untagged traffic. So switch can get ip and other config from newly created deployment DHCP scope and then it connects to pnpserver.
In total we are using additional subnet and configuration on router and DHCP server.
So maybe there is more elegant solution for that?
One more question:
After provisioning completed I have many messages in router :
Jul 12 09:47:08.305 CEST: %XML-UPDOWN: pnp-zero-touch XML Interface(101) UP. PID=218
Jul 12 09:47:08.306 CEST: %XML-UPDOWN: pnp-zero-touch XML Interface(101) DOWN(502).
What should be done to remove these messages ?
20 Replies 20
You need the following commands:
! change the PnP profile to use the management VRF
pnp profile network-pnp
transport https ipv4 x.x.x.x port 443 vrf MGMT
! change HTTP request to come from from management interface
ip http client source-interface <interface-name>
I am pretty sure you need to set the source interface as well for the HTTP request initiating from the router.  Remember, all PnP connections are initiated from the router.
Adam
I've made changs using these commands.
Seems system crashed.
chunk_diagnose, code = 3
chunk name is MallocLite
current chunk header = 0x7FBF83AB2DA0
data check, ptr = 0x7FBF83AB2DB8
next chunk header = 0x7FBF83AB2DF0
data check, ptr = 0x7FBF83AB2E08
previous chunk header = 0x7FBF83AB2D50
data check, ptr = 0x7FBF83AB2D68
========= Dump chunk = 0x7FBF83AB2DA0 ======================
7FBF83AB2CB8:     7FBF EB8F1DA1     7FBF 83AA79E0        0        0     7FBF FE92A0A0
7FBF83AB2CD8:        0        0     7FBF 831D8B20     7FBF EB88EF40        0        0
7FBF83AB2CF8:        0        0 15A3C78B        1     7FBF EB77E12F     7FBF 83AA79E0
7FBF83AB2D18:        0        0        0        0        0        0        0        3
7FBF83AB2D38:     7FBF 831D8300        9        0        0        0 15A3C78B        1
7FBF83AB2D58:     7FBF EB77E12F     7FBF 83AA79E0        0        0        0        0
7FBF83AB2D78:        0        0        0        3     7FBF 831D8788        9        0
7FBF83AB2D98:        0        0 15A3C78B FFFFFFFF     7FBF EB8F1DA1     7FBF 83AA79E0
7FBF83AB2DB8: EF4321CD        0     7FBF EB8F1DBE  B0D0B0D  B0D0B0D  B0D0B0D  B0D0B0D
7FBF83AB2DD8:  B0D0B0D  B0D0B0D  B0D0B0D  B0D0B0D  B0D0B0D        0 15A3C78B        1
7FBF83AB2DF8:     7FBF EB41B72B     7FBF 83AA79E0        0        0 DADA2012        0
7FBF83AB2E18:     7FBF EB401AF0     7FBF EB400830     7FBF 835796F0        0        0
7FBF83AB2E38:        0        0 15A3C78B        1     7FBF EB65740A     7FBF 83AA79E0
7FBF83AB2E58:        0        0 301F311D 301B0603 5504030C 1473646E 2D6E6574 776F726B
7FBF83AB2E78: 2D696E66 72612D63 61000000        0        0        0 15A3C78B        1
7FBF83AB2E98:     7FBF EB77E12F     7FBF 83AA79E0        0        0     7FBF 83AB08E0
========= Dump chunk_next = 0x7FBF83AB2DF0 ======================
7FBF83AB2CF0:        0        0        0        0 15A3C78B        1     7FBF EB77E12F
7FBF83AB2D10:     7FBF 83AA79E0        0        0        0        0        0        0
7FBF83AB2D30:        0        3     7FBF 831D8300        9        0        0        0
7FBF83AB2D50: 15A3C78B        1     7FBF EB77E12F     7FBF 83AA79E0        0        0
7FBF83AB2D70:        0        0        0        0        0        3     7FBF 831D8788
7FBF83AB2D90:        9        0        0        0 15A3C78B FFFFFFFF     7FBF EB8F1DA1
7FBF83AB2DB0:     7FBF 83AA79E0 EF4321CD        0     7FBF EB8F1DBE  B0D0B0D  B0D0B0D
7FBF83AB2DD0:  B0D0B0D  B0D0B0D  B0D0B0D  B0D0B0D  B0D0B0D  B0D0B0D  B0D0B0D        0
7FBF83AB2DF0: 15A3C78B        1     7FBF EB41B72B     7FBF 83AA79E0        0        0
7FBF83AB2E10: DADA2012        0     7FBF EB401AF0     7FBF EB400830     7FBF 835796F0
7FBF83AB2E30:        0        0        0        0 15A3C78B        1     7FBF EB65740A
7FBF83AB2E50:     7FBF 83AA79E0        0        0 301F311D 301B0603 5504030C 1473646E
7FBF83AB2E70: 2D6E6574 776F726B 2D696E66 72612D63 61000000        0        0        0
7FBF83AB2E90: 15A3C78B        1     7FBF EB77E12F     7FBF 83AA79E0        0        0
7FBF83AB2EB0:     7FBF 83AB08E0        0        0     7FBF 83AB33B0     7FBF 79C7A798
7FBF83AB2ED0:       88        0        0        0 15A3C78B        1     7FBF EB77E12F
========== Dump chunk_previous = 0x7FBF83AB2D50 =====================
7FBF83AB2C50:        9        0        0        0 15A3C78B        1     7FBF EB77E12F
7FBF83AB2C70:     7FBF 83AA79E0        0        0        0        0        0        0
7FBF83AB2C90:        0        3     7FBF 831D7FE0        9        0        0        0
7FBF83AB2CB0: 15A3C78B        1     7FBF EB8F1DA1     7FBF 83AA79E0        0        0
7FBF83AB2CD0:     7FBF FE92A0A0        0        0     7FBF 831D8B20     7FBF EB88EF40
Refcount on freed chunk is non-zero
%Software-forced reload
Frame pointer 0x7FBF83C4ED00, PC = 0x7FBFAB4791A9
-Traceback= 1#e7b171113d9d8fef543d3319f9a4e292  c:7FBFAB448000+311A9 c:7FBFAB448000+32659 :7FBFE1306000+AFFAF5E :7FBFE1306000+9F61399 :7FBFE1306000+9F43AAD :7FBFE1306000+7470804 :7FBFE1306000+7470418 :7FBFE1306000+A0E3EBA :7FBFE1306000+9536984 :7FBFE1306000+A0FABB5 :7FBFE1306000+953C5C9 :7FBFE1306000+A0C988B :7FBFE1306000+A0C94AB
Fastpath Thread backtrace:
-Traceback= 1#e7b171113d9d8fef543d3319f9a4e292  c:7FBFAB448000+BDF12
Auxiliary Thread backtrace:
-Traceback= 1#e7b171113d9d8fef543d3319f9a4e292  pthread:7FBFA569D000+A7C9
RAX = 0000000000000000  RBX = 00007FBF83C4EDB0
RCX = FFFFFFFFFFFFFFFF  RDX = 0000000000000006
RSP = 00007FBF83C4ED00  RBP = 00007FBF83C4ED00
RSI = 00000000000067D8  RDI = 00000000000067D8
R8  = 0000000000000080  R9  = 0101010101010101
R10 = 0000000000000008  R11 = 0000000000000206
R12 = 00007FBFE1219160  R13 = 046877E8BF7F0000
R14 = 0000000000000000  R15 = 00007FBF83AA79E0
RFL = 0000000000000206  RIP = 00007FBFAB4791A9
CS = 0033  FS = 0000  GS = 0000
ST0 = 0000 0000000000000000  ST1 = 0000 0000000000000000
ST2 = 0000 0000000000000000  ST3 = 0000 0000000000000000
ST4 = 0000 0000000000000000  ST5 = 0000 0000000000000000
ST6 = 0000 0000000000000000  ST7 = 0000 0000000000000000
X87CW = 037F  X87SW = 0000  X87TG = 0000  X87OP = 0000
X87IP = 0000000000000000  X87DP = 0000000000000000
XMM0  = 00000000000000000000000000000000
XMM1  = 00000000000000000000000000000000
XMM2  = 00000000000000000000000000000000
XMM3  = 00000000000000000000000000000000
XMM4  = 00000000000000000000000000000000
XMM5  = 00000000000000000000000000000000
XMM6  = 00000000000000000000000000000000
XMM7  = 00000000000000000000000000000000
XMM8  = 00000000000000000000000000000000
XMM9  = 00000000000000000000000000000000
XMM10 = FFFFFFFF000000000000000000000000
XMM11 = 00000000000000000000000000000A0A
XMM12 = 00000004000000040000000400000004
XMM13 = 0000000E000000090000000E000000D2
XMM14 = 00000000000000000000000000000000
XMM15 = FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
MXCSR = 00001FA0
Writing crashinfo to bootflash:crashinfo_RP_00_00_20170713-135922-CEST
Buffered messages:
Jul 13 13:59:18.970 CEST: %XML-UPDOWN: pnp-zero-touch XML Interface(101) DOWN(502).
Jul 13 13:59:18.970 CEST: %XML-UPDOWN: pnp-zero-touch XML Interface(101) UP. PID=364
Jul 13 13:59:18.973 CEST: %SYS-2-CHUNKBADREFCOUNT: Bad chunk reference count, chunk 7FBF83AA79E0 data 7FBF83AB2DB8 refcount FFFFFFFFFFFFFFFF alloc pc 7FBFEB8F1DA1. -Process= "XEP_pnp-zero-touch", ipl= 0, pid= 364
-Traceback= 1#e7b171113d9d8fef543d3319f9a4e292  :7FBFE1306000+9F61382 :7FBFE1306000+9F43AAD :7FBFE1306000+7470804 :7FBFE1306000+7470418 :7FBFE1306000+A0E3EBA :7FBFE1306000+9536984 :7FBFE1306000+A0FABB5 :7FBFE1306000+953C5C9 :7FBFE1306000+A0C988B :7FBFE1306000+A0C94ABJul 13 14:00:18.664 R0/0: %PMAN-3-PROCHOLDDOWN: The process linux_iosd-image has been helddown (rc 134)
Jul 13 14:00:19.028 R0/0: %PMAN-0-PROCFAILCRIT: A critical process linux_iosd_image has failed (rc 134)
Jul 13 14:00:26.885 R0/0: %PMAN-5-EXITACTION: Process manager is exiting: critical process fault, linux_iosd_image, rp_0_0, rc=134
Initializing Hardware ...
and rebooted
That is not good.
can you try without the http command?
I removed ip http client source-interface <interface-name> - System crashed.
Then I removed from pnp profile line vrf MGMT - System crashed.
Removed
pnp profile pnp-zero-touch
pnp startup-vlan 99
Everything is ok
So seems that IOS don't like pnp profile overwritting.
I found solution.
Apic-em is creating pnp profile - pnp-zero-touch.
So i just added
backup transport https host XXX.XXX.XXX.XXX port 443 vrf VRF-NAME
to that profile.
and it works.
awesome, thanks for the update.
