Rest Query with wdcard in dn => limitation
jul.delima
I'm trying (with Cobra) to retrieve some information with the Rest API. I need to retrieve the LLDP neighbors for some leaves. When I'm sending the Get REST with wildcard filter for the dn parameters, I do not receive anything back. But if I'm doing the same request but with the "eq" keyword with the full dn, I receive the information.
GET with target-filter "== / eq" :
https://APIC/api/class/lldpIf.json?query-target-filter=eq(lldpIf.dn,"topology/pod-1/node-112/sys/lldp/inst/if-[eth1/13]")
Response:
"totalCount": "1",
"imdata": [
"lldpIf": {
"attributes": {
"adminRxSt": "enabled",
"adminSt": "enabled",
"adminTxSt": "enabled",
"childAction": "",
"descr": "",
"dn": "topology/pod-1/node-112/sys/lldp/inst/if-[eth1/13]",
"id": "eth1/13",
"lcOwn": "local",
"mac": "xxxxxxx",
"modTs": "2020-06-17T15:33:16.370+01:00",
"monPolDn": "uni/fabric/monfab-default",
"name": "",
"operRxSt": "down",
"operTxSt": "down",
"portDesc": "topology/pod-1/paths-112/pathep-[eth1/13]",
"portMode": "normal",
"portVlan": "unspecified",
"status": "",
"sysDesc": "topology/pod-1/node-112",
"wiringIssues": ""
GET with target-filter "contains / wcard" :
https://APIC/api/class/lldpIf.json?query-target-filter=wcard(lldpIf.dn,"node-112")
Response:
"totalCount": "0",
"imdata": []
But If I do this kind of filter with the sysDesc paramter, it's working ! What is the limit with the dn ?
Thank in advance
kkhlebop
Hello jul.delima,
Give the wcard a shot with some asterisks for globbing. Also, I saw documentation that it might work with regex. Most likely the syntax actually leans towards regex rather then globbing (they are similar but different).
I noticed on this link https://www.ciscolive.com/c/dam/r/ciscolive/apjc/docs/2016/pdf/DEVNET-1627.pdf on page 17 we have this example: query-target-filter=wcard(fvTenant.description,"coke.*”) # filter with regex
So in your case, give these a shot, let us know if one works:
https://APIC/api/class/lldpIf.json?query-target-filter=wcard(lldpIf.dn,".*node-112.*")
https://APIC/api/class/lldpIf.json?query-target-filter=wcard(lldpIf.dn,"*node-112*")
https://APIC/api/class/lldpIf.json?query-target-filter=wcard(lldpIf.dn,"node-112.*")
https://APIC/api/class/lldpIf.json?query-target-filter=wcard(lldpIf.dn,"node-112*")
Note: the astrick might need to be urlencoded to %2A, so then might also want to try these:
https://APIC/api/class/lldpIf.json?query-target-filter=wcard(lldpIf.dn,".%2Anode-112.%2A")
https://APIC/api/class/lldpIf.json?query-target-filter=wcard(lldpIf.dn,"%2Anode-112%2A")
https://APIC/api/class/lldpIf.json?query-target-filter=wcard(lldpIf.dn,"node-112.%2A")
https://APIC/api/class/lldpIf.json?query-target-filter=wcard(lldpIf.dn,"node-112%2A")
Kostia Khlebopros
Hello Kostia,
Thanks for your answer. I tried all the possibilites that you mentioned. Unfortunately without success. With the asterisk coding, I receive more object than expected.
But If I do a wildcard search with the interface name, I receive the correct answer :
https://{{apic}}/api/class/lldpIf.json?query-target-filter=wcard(lldpIf.dn,"eth1/49")
"totalCount": "8",
"imdata": [
"lldpIf": {
"attributes": {
"childAction": "",
"descr": "",
"dn": "topology/pod-1/node-101/sys/lldp/inst/if-[eth1/49]",
"id": "eth1/49",
"lcOwn": "local",
-- output ommited ---
By the way I needed this request to use with cobra SDK python package. But I found the "lookupByClass" method where I can put the parent DN in parameter and therefore retrieve only the class for a given node.
Otherwise, the workaround is to add the path in the URL and you can filter the node :
Ex :
'https://<APIC>/api/node/class/topology/pod-1/node-121/lldpIf.json?rsp-subtree=children&rsp-subtree-class=lldpIf,lldpAdjEp&rsp-subtree-include=required'
I am not so expert with REST in order to see if this problem is a Bug or limitation...
Are you working in this area ?
Julian de Lima
Ruben Cocheno
@jul.delima
Just following up on this and see if you still need help?
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
hrtendrup-old
Coincidentally, I ran across this post for the same use case as the OP. I have the same issues. While filtering on lldpIf.sysDesc is a feasible workaround, IMO, I'm very curious as to why lldpIf.dn is a no go.
Running ACI 4.2(7r) / 14.2(7r)
The queries I use:
https://apic/api/class/lldpIf.json?rsp-subtree=children&rsp-subtree-class=lldpAdjEp&rsp-subtree-include=required&query-target-filter=wcard(lldpIf.dn,"node-101")
returned 0 results (there ARE LLDP neighbors on node 101)
https://apic/api/class/lldpIf.json?rsp-subtree=children&rsp-subtree-class=lldpAdjEp&rsp-subtree-include=required&query-target-filter=wcard(lldpIf.dn,"node")
returned 6 results - 2 for each of my 3 APICs' - connections to the fabric
https://apic/api/class/lldpIf.json?rsp-subtree=children&rsp-subtree-class=lldpAdjEp&rsp-subtree-include=required&query-target-filter=wcard(lldpIf.dn,".*")
returned 444 results - spot check seems to indicate this would be all LLDP neighbors for the entire fabric (using Python lib - did NOT encode the * as %2A)
https://apic/api/class/lldpIf.json?rsp-subtree=children&rsp-subtree-class=lldpAdjEp&rsp-subtree-include=required&query-target-filter=wcard(lldpIf.dn,".*node-101.*")
returned 0 results
https://apic/api/class/lldpIf.json?rsp-subtree=children&rsp-subtree-class=lldpAdjEp&rsp-subtree-include=required&query-target-filter=wcard(lldpIf.sysDesc,"node-101")
returned 7 results - the 7 lldp neighbors on node 101 in my fabric - seemingly a different way to get the desired results
As a matter of testing, I tried for an entirely different class (randomly selected from my list of queries I've used).
https://apic/api/class/fvBD.json?rsp-subtree=children&rsp-subtree-class=fvSubnet&rsp-subtree-include=required&query-target-filter=wcard(fvBD.dn,"vmware")
This returned 3 results, all with "vmware" somewhere in the dn field. This seems to work as expected.
