Elvin J
Firstly, I want to say that, I just started learning NSO, that is why my question might be primitive, sorry for that.
What are the template files (XML files under template folder) ?  why they are used? when they should be changed?  and mainly, who uses those templates after applying parameters to templates?  Let's say I apply new parameter to template, should I change template accordingly?
Would be much helpful if you help me to understand this part
1 Comment
hazad
Templates are used to apply config anywhere to the NSO CDB. You save your XML-files in the template folder which allows the template API to find them, when invoked from your package code. But I don't think I'll be able to explain it any better than our documentation: https://developer.cisco.com/docs/nso/guides/#!templates
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
