Nicklas Wagerth
Efficient Multi-AZ CNC Solution Deployment in AWS Using CloudFormation Templates
Automation Developer Days US, Dec 6, 2023
Abstract:
In this informative session, you will learn how to easily deploy the Crosswork Network Controller (CNC) solution in Amazon Web Services (AWS) across multiple Availability Zones (Multi-AZ). By utilizing infrastructure as code (IaC) tools like AWS CloudFormation, you will discover the streamlined process of deploying CNC and Crosswork Data Gateway (CDG) clusters in a Multi-AZ environment. With just a few clicks, you can deploy the Crosswork Network Controller tailored to your specific network design in AWS. Additionally, you will also learn how to integrate CNC APIs into cloud formation templates as part of the CNC deployment process. Join us to effortlessly deploy the Crosswork Network Controller in AWS and enhance your knowledge in this area.
Link to recording
Speaker: Sriharsha Dhanekula, Technical Marketing Engineering Technical Leader
Operations Track, Day 2Operations Track, Day 2
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
