frjansso
Create the Device
curl -H "Content-Type:application/vnd.yang.data+xml" -X PUT -u admin:admin -d @ios3.xml http://localhost:8080/api/running/devices/device/ios3
Fetch SSH Keys
curl -H "Content-Type:application/vnd.yang.data+xml" -X POST -u admin:admin http://localhost:8080/api/running/devices/device/ios3/ssh/_operations/fetch-host-keys
Sync From
curl -H "Content-Type:application/vnd.yang.data+xml" -X POST -u admin:admin http://localhost:8080/api/running/devices/device/ios3/_operations/sync-from
ios3.xml
<device xmlns="http://tail-f.com/ns/ncs">
  <name>ios3</name>
  <address>127.0.0.1</address>
  <port>10022</port>
  <state>
    <admin-state>unlocked</admin-state>
  </state>
  <authgroup>default</authgroup>
  <device-type>
    <cli>
   <ned-id xmlns:ios-id="urn:ios-id">ios-id:cisco-ios</ned-id>
    </cli>
  </device-type>
</device
yfherzog
@Islam_Hassanin if you want to use POST call then you'd need to provide the URI to the device-name list, and provide the new device-name instance in the payload.
If you want to add multiple devices to a group, you need to run a PATCH call on the same URI, and provide all new instances in the payload.
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
