Mohammed786
Hi All,
i am going to deploy Hyperflex with Vmware for Testing Purposes.
Are there CLI commands to do a factory reset of a new Hyperflex system and rebuild hyper flex again?
is there any procedure for rebuild Hyperflex?
2 Comments
Eric Rose
bezeddin
Since the cluster is for testing purpose you can directly reinstall ESXi using .iso custom image for Hyperflex
after all nodes installed with ESXi you can continue with adding nodes to Intersight
and for the rest you can continue with Hyperflex Edge deployment guide
Budi
