Abey K. George
Document Objective
This document discuss a common issue observed during the VMM integration & VM workload migration to ACI fabric.
Problem Description
VMware Virtual machines are hosted in Cisco UCS-B series blade servers (ESXi servers). UCS Fabric interconnect is connected to leaf101 & leaf102 (vPC - LACP active).
EPG "abegeorg:webinar:app" has a VMM domain (VMWare DVS) deployed, so the corresponding port-group will be created for VMWare DVS.
Once the VMM integration (VMWare DVS) is completed and migrated the VM workload to ACI managed DVS, intermittent connectivity issue is observed with the newly migrated VM. Users are experiencing the slowness in accessing the services, sometimes services are not accessible.
The example VM considered for this troubleshooting is IP -> 10.10.92.1/24, the default GW of this endpoint is residing in ACI fabric (10.10.92.254/24)
Common troubleshooting steps
This sections covers common troubleshooting steps can be used to isolate similar issues. You are encouraged to use these steps to troubleshoot such connectivity issues.
Validating the connectivity
Now, lets check some connectivity state and validate how the ACI fabric is connected to the server (in this case UCS B-Series chassis). The CDP and port-channel output obtained below indicates that the FI-A & FI-B are connected to ACI fabric leaf (leaf101 & leaf102) using vPC. The vPC ports and up.
leaf101# show cdp neighbors
<< snip >>
UCS-ACI-PODs-A(SSI182207R7) Eth1/37 171 S I s UCS-FI-6248UP Eth1/5
UCS-ACI-PODs-B(SSI1822054V) Eth1/38 127 S I s UCS-FI-6248UP Eth1/5
<< snip >>
leaf101#
leaf101# show vpc extended
<< snip >>
691 Po9   up success success 3874-3875,3887 abegeorg-ucs-a-vpc
692 Po10 up success success 3874-3875,3887 abegeorg-ucs-b-vpc
<< snip >>
leaf101#
leaf101# show port-channel extended
<< snip >>
9   Po9(SU)   abegeorg-ucs-a-vpc LACP Eth1/37(P)
10 Po10(SU) abegeorg-ucs-b-vpc LACP Eth1/38(P)
leaf101#
leaf102# show cdp neighbors
<< snip >>
UCS-ACI-PODs-A(SSI182207R7) Eth1/37 165 S I s UCS-FI-6248UP Eth1/6
UCS-ACI-PODs-B(SSI1822054V) Eth1/38 121 S I s UCS-FI-6248UP Eth1/6
<< snip >>
leaf102#
leaf102# show vpc extended
<< snip >>
691 Po8 up success success 3874-3875,3887 abegeorg-ucs-a-vpc
692 Po9 up success success 3874-3875,3887 abegeorg-ucs-b-vpc
<< snip >>
leaf102#
leaf102# show port-channel extended
<< snip >>
8 Po8(SU) abegeorg-ucs-a-vpc LACP Eth1/37(P)
9 Po9(SU) abegeorg-ucs-b-vpc LACP Eth1/38(P)
leaf102#
In this case, the default GW of the VM workload is at the ACI fabric. So,  lets do some connectivity test from ACI fabric. The iping result indicates that there are intermittent ping drops, the connectivity from the ACI fabric itself is having issue.
iPing test
leaf101# iping -V abegeorg:webinar 10.10.92.1 -c 20
PING 10.10.92.1 (10.10.92.1) from 10.10.92.254: 56 data bytes
Request 0 timed out
64 bytes from 10.10.92.1: icmp_seq=1 ttl=64 time=0.277 ms
64 bytes from 10.10.92.1: icmp_seq=2 ttl=64 time=0.346 ms
64 bytes from 10.10.92.1: icmp_seq=3 ttl=64 time=0.341 ms
64 bytes from 10.10.92.1: icmp_seq=4 ttl=64 time=0.445 ms
Request 5 timed out
Request 6 timed out
Request 7 timed out
Request 8 timed out
Request 9 timed out
64 bytes from 10.10.92.1: icmp_seq=10 ttl=64 time=0.292 ms
64 bytes from 10.10.92.1: icmp_seq=11 ttl=64 time=0.305 ms
64 bytes from 10.10.92.1: icmp_seq=12 ttl=64 time=0.348 ms
64 bytes from 10.10.92.1: icmp_seq=13 ttl=64 time=0.327 ms
64 bytes from 10.10.92.1: icmp_seq=14 ttl=64 time=0.48 ms
64 bytes from 10.10.92.1: icmp_seq=15 ttl=64 time=0.323 ms
64 bytes from 10.10.92.1: icmp_seq=16 ttl=64 time=0.314 ms
Request 17 timed out
Request 18 timed out
64 bytes from 10.10.92.1: icmp_seq=19 ttl=64 time=0.324 ms
--- 10.10.92.1 ping statistics ---
20 packets transmitted, 12 packets received, 40.00% packet loss
round-trip min/avg/max = 0.277/0.343/0.48 ms
leaf101#
Verify Endpoint learning
Now, lets check the endpoint learning details...  When I tried "show system internal epm endpoint ip 10.10.92.1" between two times in two minutes interval, we are seeing the endpoint is moving between two distinct interfaces po9 & po10. The po9 and po10 are the connections to FI-A and FI-B respectively. This means that the traffic from 10.10.92.1 is load-balanced between FI-A and FI-B, which is not expected.
leaf101# show system internal epm endpoint ip 10.10.92.1
MAC : 0050.5690.864e ::: Num IPs : 2
IP# 0 : 172.16.200.104 ::: IP# 0 flags :
IP# 1 : 10.10.92.1 ::: IP# 1 flags :
Vlan id : 44 ::: Vlan vnid : 13106 ::: VRF name : abegeorg:webinar
BD vnid : 16613251 ::: VRF vnid : 2129922
Phy If : 0x16000009 ::: Tunnel If : 0
Interface : port-channel10
Flags : 0x80005c05 ::: sclass : 21 ::: Ref count : 6
EP Create Timestamp : 04/05/2018 10:20:37.357432
EP Update Timestamp : 04/06/2018 10:59:26.854181
EP Flags : local|vPC|IP|MAC|host-tracked|sclass|timer|
leaf101# show clock
11:00:07.059408 CST Fri Apr 06 2018
leaf101#
leaf101#
Phy If : 0x16000008 ::: Tunnel If : 0
Interface : port-channel9
EP Update Timestamp : 04/06/2018 11:00:52.054097
leaf101#
Unfortunately, it is very hard for you to get the timing correct when you attempt to do "show system internal epm endpoint ip 10.10.92.1" twice. Hence, another way you can check the endpoint learning behaviour in by reviewing the EPM traces as shown below...
Reviewing EPM trace for endpoint move
leaf101# grep 10.10.92.1 -A6 -B8 /var/log/dme/log/epm-trace.txt | more
[2018 Apr 6 10:40:05.093513948:9945985:epm_add_or_mod_ip_ep_obj:1803:t] Mac-to-IP relation obj added to objstore with Dn sys/ctx-[vxlan-2129922]/bd-[vxlan-16613251]/vlan-[vlan-3874]/db-ep/mac-00:50:56:90
:86:4E/rsmacEpToIpEpAtt-[sys/ctx-[vxlan-2129922]/bd-[vxlan-16613251]/vlan-[vlan-3874]/db-ep/ip-[172.16.200.104]]
[2018 Apr 6 10:40:05.093566785:9945986:epm_add_or_mod_ip_ep_obj:1789:t] Add/Mod of IpEp obj with Dn sys/ctx-[vxlan-2129922]/bd-[vxlan-16613251]/vlan-[vlan-3874]/db-ep/ip-[10.10.92.1]
[2018 Apr 6 10:40:05.093617536:9945987:epm_add_or_mod_ip_ep_obj:1803:t] Mac-to-IP relation obj added to objstore with Dn sys/ctx-[vxlan-2129922]/bd-[vxlan-16613251]/vlan-[vlan-3874]/db-ep/mac-00:50:56:90
:86:4E/rsmacEpToIpEpAtt-[sys/ctx-[vxlan-2129922]/bd-[vxlan-16613251]/vlan-[vlan-3874]/db-ep/ip-[10.10.92.1]]
[2018 Apr 6 10:40:05.093619163:9945988:epm_attach_to_dirty_vlan_list:4359:t] Adding vlan 44 to dirty list with version 120505
[2018 Apr 6 10:40:05.093622239:9945989:epm_debug_dump_epm_ep:398:t] log_collect_ep_event
EP entry:
mac = 0050.5690.864e; num_ips = 2
ip[0] = 172.16.200.104
ip[1] = 10.10.92.1
vlan = 44; epg_vnid = 13106; bd_vnid = 16613251; vrf_vnid = 2129922
ifindex = 0x16000009; tun_ifindex = 0; vtep_tun_ifindex = 0
sclass = 21; ref_cnt = 6
flags = local|vPC|IP|MAC|host-tracked|sclass|timer|
create_ts = 04/05/2018 10:20:37.357432
upd_ts = 04/06/2018 10:40:07.854374
[2018 Apr 6 10:40:05.392355836:9946083:epm_add_or_mod_ip_ep_obj:1803:t] Mac-to-IP relation obj added to objstore with Dn sys/ctx-[vxlan-2129922]/bd-[vxlan-16613251]/vlan-[vlan-3874]/db-ep/mac-00:50:56:90
[2018 Apr 6 10:40:05.392408865:9946084:epm_add_or_mod_ip_ep_obj:1789:t] Add/Mod of IpEp obj with Dn sys/ctx-[vxlan-2129922]/bd-[vxlan-16613251]/vlan-[vlan-3874]/db-ep/ip-[10.10.92.1]
[2018 Apr 6 10:40:05.392460098:9946085:epm_add_or_mod_ip_ep_obj:1803:t] Mac-to-IP relation obj added to objstore with Dn sys/ctx-[vxlan-2129922]/bd-[vxlan-16613251]/vlan-[vlan-3874]/db-ep/mac-00:50:56:90
[2018 Apr 6 10:40:05.392461585:9946086:epm_attach_to_dirty_vlan_list:4359:t] Adding vlan 44 to dirty list with version 120506
[2018 Apr 6 10:40:05.392464652:9946087:epm_debug_dump_epm_ep:398:t] log_collect_ep_event
EP entry:
ip[1] = 10.10.92.1
ifindex = 0x16000008; tun_ifindex = 0; vtep_tun_ifindex = 0
upd_ts = 04/06/2018 10:40:08.154360
Now, get the interface name from ifindex to validate
leaf101# vsh_lc
vsh_lc
module-1# show system internal eltmc info interface ifindex 0x16000008
IfInfo:
interface: port-channel9 ::: ifindex: 369098760
iod: 110 ::: state: up
module-1# show system internal eltmc info interface ifindex 0x16000009
IfInfo:
interface: port-channel10 ::: ifindex: 369098761
module-1#
Review the Endpoint state transition using EP tracker
Now, another easy way to review the endpoint move is from GUI. Navigate to Operations -> EP Tracker, input endpoint IP or MAC for endpoint seach, once the endpoint details are displayed, click on it to get the state transition details. The endpoint state transition details for 10.10.92.1 is clearly indicating that the endpoint is moving between abegeorg-ucs-a-vpc and abegeorg-ucs-b-vpc continuously.
Based on the review so far, we see that the traffic from the VM (10.10.92.1) is load-balanced across both FI-A and FI-B side, which is not supported for UCS-B series chassis deployment. The only supported load balancing mechanism when UCS B series is used is Route Based on Originating Virtual Port, which is expected to either through FI-A or FI-B (not both). So, now lets review the load-balancing policy configured at the DVS.
Review the DVS load-balancing policy at vCenter
LACP is enabled for DVS uplink, which is not expected.
The load-balancing policy for the DVS port-group is configured with "Route based on IP hash", but the supported mode is "Route Based on Originating Virtual Port" for UCS-B based deployment.
Please note: The DVS vSwitch policy is not manually configured at the vCenter, rather it is pushed from APIC as part of the VMM domain integration. So, how does this invalid policy is being pushed? This happens because we haven't used an explicit vSwitch policy for VMM domain,so it uses the interface policy (the interface policy we configured for leaf101/leaf102 to FI-A/FI-B is LACP active).
Review the vSwitch for VMM domain
We can see that the vSwitch policy has not configured here.
Resolution steps
The vSwitch policy for the VMM Domain shall be configured with MAC-pinning to fix this issue
Screen Shot 2018-04-06 at 1.21.28 PM.pngScreen Shot 2018-04-06 at 1.21.12 PM.png
Verification
Now, lets verify at vCenter and review how this policy is applied to the DVS. The following screenshot indicates that the DVS uplink LACP is disabled and the correct changes has been pushed from APIC to vCenter.
The DVS port-group load-balancing policy has been changed to "Route based on originating virtual port", this is expected as per the vSwitch policy is configured for VMM domain.
Applying the correct vSwitch policy helped the connectivity issue to be resolved...
64 bytes from 10.10.92.1: icmp_seq=0 ttl=64 time=0.399 ms
64 bytes from 10.10.92.1: icmp_seq=1 ttl=64 time=0.362 ms
64 bytes from 10.10.92.1: icmp_seq=2 ttl=64 time=0.302 ms
64 bytes from 10.10.92.1: icmp_seq=3 ttl=64 time=0.382 ms
64 bytes from 10.10.92.1: icmp_seq=4 ttl=64 time=0.353 ms
64 bytes from 10.10.92.1: icmp_seq=5 ttl=64 time=0.352 ms
64 bytes from 10.10.92.1: icmp_seq=6 ttl=64 time=0.43 ms
64 bytes from 10.10.92.1: icmp_seq=7 ttl=64 time=0.375 ms
64 bytes from 10.10.92.1: icmp_seq=8 ttl=64 time=0.351 ms
64 bytes from 10.10.92.1: icmp_seq=9 ttl=64 time=0.319 ms
64 bytes from 10.10.92.1: icmp_seq=10 ttl=64 time=0.347 ms
64 bytes from 10.10.92.1: icmp_seq=11 ttl=64 time=0.382 ms
64 bytes from 10.10.92.1: icmp_seq=12 ttl=64 time=0.331 ms
64 bytes from 10.10.92.1: icmp_seq=13 ttl=64 time=0.344 ms
64 bytes from 10.10.92.1: icmp_seq=14 ttl=64 time=0.302 ms
64 bytes from 10.10.92.1: icmp_seq=15 ttl=64 time=0.352 ms
64 bytes from 10.10.92.1: icmp_seq=16 ttl=64 time=0.368 ms
64 bytes from 10.10.92.1: icmp_seq=17 ttl=64 time=0.348 ms
64 bytes from 10.10.92.1: icmp_seq=18 ttl=64 time=0.272 ms
64 bytes from 10.10.92.1: icmp_seq=19 ttl=64 time=0.317 ms
20 packets transmitted, 20 packets received, 0.00% packet loss
round-trip min/avg/max = 0.272/0.349/0.43 ms
leaf101#
izzy_m
Frequent Visitor
Frequent Visitor
Hi Abey, Very nice write up. Our team was struggling to understand what is the correct policy to be used between Leafs->FI and ACI->VMM DVS switch. So we discovered the same thing - Leafs->FI using vPC LACP as per your diagram and on the ACI-managed VMM DVS - Mac Pinning. So is this official - we shouldn't be using LACP-Active on the VDS switch policy? Thanks, Izzy
