Yoshitaka Yanomori
Introduction
This document explains about L3Out basic troubleshooting.
Please refer to L3Out here.
ACI Topology
The topology is as shown below and the communication is from external EP (1.2.3.4/32) to Server-A placed under Leaf103/104 (Server Leaf). The external network is in Tenant: Cisco(vrf1), and Server-A belongs to Tenant: Datacenter(vrf2).
Prerequisite
- ACI Version: 4.1(1i) and Leaf devices are 9300 EX series switches.
- The configuration for Access Policy, Tenant, VRF, BD、External Routed Network are already done.
- Some configuration note:
(1) The following scope are checked under External Routed Networks > External Network Instance Profile > Subnets
This is required to share routes between vrfs and allow the communication.
       - External Subnets for the External EPG
       - Shared Route Control Subnet
       - Shared Security Import Subnet
(2) Check "Shared between VRFs" Scope for Subnet under Server-A EPG.
Best Practice of shared service is to configure hared Subnet under provider EPG subnet.
For detail, refer to "Guidelines and Limitations for Shared Services".
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/1-x/ACI_Best_Practices/b_ACI_Best_Practices/b_ACI_…
(3) Contract
Create provided contract in Server-A EPG then export it to Cisco Tenant.
Then, apply the contract as consumed interface under External Routed Networks >External Network Instance Profile.
  # Configuring Inter-Context Communication
Verify Boarder Leaf side
Firstly, check if the external route (1.2.3.4/32) is learnt on boarner leaf.
If the route is not learnt, it is possible that some L3Out configurations are wrong or neighbor session is not established, in this case OSPF neighbor.
Boarder Leaf
leaf3# show ip route 1.2.3.4 vrf Cisco:vrf1
-- snip --
1.2.3.4/32, ubest/mbest: 1/0
    *via 192.168.2.100, vlan104, [110/5], 1d23h, ospf-default, intra
How to check OSPF Neighbor
Boarder Leaf
leaf3# show ip ospf neighbors vrf Cisco:vrf1
OSPF Process ID default VRF Cisco:vrf1
Total number of neighbors: 2
Neighbor ID    Pri State            Up Time  Address        Interface
4.4.4.4          1 FULL/BDR        1d23h    192.168.2.201  Vlan104
1.2.3.4          1 FULL/DR          1d23h    192.168.2.100  Vlan104
Also, check the Server-A's subnet (100.125.255.0/24) is correctly imported on boarder leaf.
If the subnet is not on boarder lear, it is possible that "Shared between VRFs" is not checked in the above Prerequisite(2) section.
Boarder Leaf
leaf3# show ip route 100.125.255.0 vrf Cisco:vrf1
-- snip --
100.125.255.0/24, ubest/mbest: 1/0, attached, direct, pervasive
    *via 10.0.112.65%overlay-1, [1/0], 00:00:50, static, tag 4294967295
        recursive next hop: 10.0.112.65/32%overlay-1
Verify Server Leaf side
Next, check if the external route (1.2.3.4/32) is learnt on server leaf.
If the route is not learnt, it is possible that contracts in Prerequisite(3) section might be wrong, or some required scopes are not checked as described in Prerequisite(1).
In the following example, the two TEP address 10.0.64.127 and 10.0.136.65 are shown. These are Leaf4 and Leaf3 which can be confirmed by "acidiag fnvread".
Server Leaf
leaf1# show ip route 1.2.3.4 vrf Datacenter:vrf2
-- snip --
1.2.3.4/32, ubest/mbest: 2/0
    *via 10.0.64.127%overlay-1, [200/5], 1d23h, bgp-101, internal, tag 101
        recursive next hop: 10.0.64.127/32%overlay-1
    *via 10.0.136.65%overlay-1, [200/5], 1d23h, bgp-101, internal, tag 101
        recursive next hop: 10.0.136.65/32%overlay-1
Relation of TEP and Node
Server Leaf
leaf1# acidiag fnvread
      ID  Pod ID          Name    Serial Number        IP Address    Role        State  LastUpdMsgId
    103        1          leaf3      FDO21162J7H    10.0.136.65/32    leaf        active  0
    104        1          leaf4      FDO21162HY8    10.0.64.127/32    leaf        active  0
-- snip --
Verify Contract
Let's check contract if the communication still fails even the routes are correctly learnt on boarder/server leaf.
Firstly, we need to check VRF VNID (scope).
From GUI, the segment Id under vrf policy is VRF VNID (scope).
From console, we can check it by "moquery -c l3Ctx".
Boarder Leaf
leaf3# moquery -c l3Ctx | egrep "\#|encap|ctxPKey|scope"
-- snip --
# l3.Ctx
encap              : vxlan-3047430
ctxPKey            : uni/tn-Cisco/ctx-vrf1
scope              : 3047430
Server Leaf
leaf1# moquery -c l3Ctx | egrep "\#|encap|ctxPKey|scope"
-- snip --
# l3.Ctx
encap              : vxlan-2850819
ctxPKey            : uni/tn-Datacenter/ctx-vrf2
scope              : 2850819
Next, check if the contract is correctly applied using VRF VNID (scope).
# The procedure is same on boarder and service leaf. The following example is on boarder leaf.
Applied rules can be confirmed by "show zoning-rule scope <VRF VNID> "
Boarder Leaf
leaf3# show zoning-rule scope 3047430
| Rule ID | SrcEPG | DstEPG | FilterID |      Dir      |  operSt |  Scope  |  Name      |  Action  |        Priority       |
|  4122   |  0     |  0     | implicit |    uni-dir    | enabled | 3047430 |            | deny,log |    any_any_any(21)    |
|  4123   |  0     |  0     | implarp  |    uni-dir    | enabled | 3047430 |            |  permit  |  any_any_filter(17)   |
|  4124   |  0     |  15    | implicit |    uni-dir    | enabled | 3047430 |            | deny,log |  any_vrf_any_deny(22) |
|  5637   |  84    |  0     | implicit |    uni-dir    | enabled | 3047430 |            | deny,log | shsrc_any_any_deny(12)|
|  4252   |  5518  |  84    |  306     |    bi-dir     | enabled | 3047430 | server_ssh |  permit  |    fully_qual(7)      |
|  4247   |  84    |  5518  |  307     |uni-dir-ignore | enabled | 3047430 | server_ssh |  permit  |    fully_qual(7)      |
In this case, DstEPG 5518 is External EPG and SrcEPG 84 is Server-A (100.125.255.10/24). If a zoning-rule is not created like this, configuration of contract would be something wrong.
EPG's sclass(pcTag) can be confirmed by GUI or CLI. Refer to Appendix-1 below.
From the above rules, the communication matching to FiterID 306 and 307 are permitted. (5518 --> 84 / 84 --> 5518)
ssh (tcp22) is permitted in this case, Reverse Filter Ports (bi-dir) is checked in contract subject.
In the next step, check "policy-mgr stats" and if counters for matched Rule ID is incremented.
Rule ID 4252 should be incremented in this case.
If this counter is not incremented, it is possible that Server-A's subnet is not imported on boarder leaf or contract issue is there.
Also, if receiving traffic which is not permitted, implicit deny is incremented. Rule 4122 is in this case.
Boarder Leaf
leaf3# show system internal policy-mgr stats | grep 3047430
Rule (4122) DN (sys/actrl/scope-3047430/rule-3047430-s-any-d-any-f-implicit) Ingress: 0, Egress: 0, Pkts: 11  RevPkts: 0
Rule (4123) DN (sys/actrl/scope-3047430/rule-3047430-s-any-d-any-f-implarp) Ingress: 0, Egress: 0, Pkts: 0  RevPkts: 0
Rule (4124) DN (sys/actrl/scope-3047430/rule-3047430-s-any-d-15-f-implicit) Ingress: 0, Egress: 0, Pkts: 0  RevPkts: 0
Rule (4247) DN (sys/actrl/scope-3047430/rule-3047430-s-84-d-5518-f-307) Ingress: 0, Egress: 0, Pkts: 0  RevPkts: 0
Rule (4252) DN (sys/actrl/scope-3047430/rule-3047430-s-5518-d-84-f-306) Ingress: 0, Egress: 0, Pkts: 32  RevPkts: 0
Rule (5637) DN (sys/actrl/scope-3047430/rule-3047430-s-84-d-any-f-implicit) Ingress: 0, Egress: 0, Pkts: 0  RevPkts: 0
SPAN/ELAM Analysis
SPAN/ELAM is good option if the communication still fails even the routes and contract are correct.
ACI SPAN
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/1-x/cli/nx/cfg/b_APIC_NXOS_CLI_User_Guide/b_APIC_NXOS_CLI_User_Guide_chapter_010000.html
ACI ELAM Assistant
https://learningnetwork.cisco.com/docs/DOC-34985
Appendix-1: How to confirm sclass(pcTag) for EPG / External EPG
From GUI:
<External EPG>
  Tenants > Tenant name > Operational > Resource IDs > External Networks Instance Profile (Class ID)Screen Shot 0031-04-17 at 2.29.16 PM.png
or
 Tenants > External Routed Networks > Networks > Networks Instance Profile (pcTag)
<EPG>
  Tenant > Tenant name > AP > EPG > policy > General > pcTag(sclass)
From CLI:
<External EPG> vsh -c "show system internal policy-mgr prefix"
Boarder Leaf
leaf3# vsh -c "show system internal policy-mgr prefix" | egrep "Class|1.2.3.4"
Vrf-Vni VRF-Id Table-Id Table-State  VRF-Name      Addr      Class Shared Remote Complete
3047430 12    0xc          Up    Cisco:vrf1      1.2.3.4/32  5518    True  True  False
# In 3.1 or earlier releases, vsh_lc -c "show system internal aclqos prefix"
<EPG> show system internal epm endpoint ip 100.125.255.10
Server Leaf
leaf1# show system internal epm endpoint ip 100.125.255.10
MAC : 0050.5690.40e3 ::: Num IPs : 1
IP# 0 : 100.125.255.10 ::: IP# 0 flags :  ::: l3-sw-hit: No
Vlan id : 32 ::: Vlan vnid : 30065 ::: VRF name : Datacenter:vrf2
BD vnid : 16285706 ::: VRF vnid : 2850819
Phy If : 0x1a02c000 ::: Tunnel If : 0
Interface : Ethernet1/45
Flags : 0x80005c04 ::: sclass : 84 ::: Ref count : 5
Appendix-2: How to confirm Nexthop Table
Regarding nexthop entry in route table, we can check the consistency of hardware table as following step.
It is good option to check this table in some cases such as failing to receive packet or forwarding to wrong destination.
# The method is applicable to only EX/FX series
1) vsh_lc -c "show platform internal hal l3 routes"  and find "NB HW Idx" for target external route.
In this case, NB HW Idx is "802e" for 1.2.3.4/32. NB (NextBaseType) は A = Adjacency.
 # If the target route is ECMP, NB (NextBaseType) is E (= Ecmp). Refer to later section.
2) Next, vsh_lc -c "show plat int hal l3 nexthops" and find "HIT IDX (H)" matches to "NB HW Idx" confirmed in above 1).
This result shows, IP address / MAC address for nexthop.
ECMP case:
2) N (Next Base ID) shows "E" is ECMP entry.
3) vsh_lc -c "show platform internal hal l3 ecmp ecmp-id " <NB-ID>
In this case, 0x24.
Server Leaf
leaf1# vsh_lc -c "show platform internal hal l3 ecmp ecmp-id 0x24" | grep Nhop
Mbr[0] LID:0 NhopId:30315 L2ptr:0x8049
Mbr[1] LID:0 NhopId:30317 L2ptr:0x804b
4) From these steps, we can see multiple NhopId.
5) vsh_lc -c "show platform internal hal l3 nexthop nexthop-id <XXXXX>"
Server Leaf
leaf1# vsh_lc -c "show platform internal hal l3 nexthop nexthop-id 30315" | grep IPv4
IPv4 Address                  : 10.0.136.65
leaf1#
leaf1# vsh_lc -c "show platform internal hal l3 nexthop nexthop-id 30317" | grep IPv4
IPv4 Address                  : 10.0.64.127
Reference
Cisco APIC Layer 3 Networking Configuration Guide, Release 4.0(1)
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/4-x/L3-configuration/Cisco-APIC-Layer-3-Networking…
