Sandeep Singh
Level 7
Level 7
Introduction
Cisco Service Module-Services Ready Engine (Cisco SM-SRE) hosted by the Cisco ISR G2 have their own processors, storage, network interfaces, and memory that operate independently of the host router resources. This configuration helps to ensure maximum concurrent routing and application performance. Cisco SRE supports installing and uninstalling Cisco-authorized software, such as Cisco Unity Express, Cisco Application eXtension Platform (Cisco AXP), and Cisco IP Video Surveillance using Cisco IOS software commands and prevents unauthorized software and applications from running on Cisco SRE modules.  After the application software is installed, the SMs have their own startup and run-time configurations that are independent of the Cisco IOS configuration on the host router. The SMs do not have an external console port.
Configuration
The configuration part is divided into two parts. Router config and WAAS module config.
Router Config
hostname Router
ip wccp 61
ip wccp 62
ip cef
ip domain name yourdomain.com
interface FastEthernet0/0
ip address 10.10.10.1 255.255.255.0
ip wccp 61 redirect in
ip wccp 62 redirect out
bandwidth 100
full-duplex
interface Serial0
ip address 172.16.223.12 255.255.255.0
WAAS module Config
device mode application-accelerator
hostname WAE
primary-interface GigabitEthernet 1/0
ip address 10.10.10.250 255.255.255.0
no autosense
bandwidth 100
full-duplex
exit
interface GigabitEthernet 2/0
shutdown
exit
ip default-gateway 10.10.10.1
ip route 192.168.10.1 255.255.255.255 10.1.1.1
ip route 192.168.10.11 255.255.255.255 10.1.2.1
!ip name-server 10.10.10.100
wccp router-list 1 10.10.1.1
wccp tcp-promiscuous router-list-num 1
wccp version 2
egress-method negotiated-return intercept-method wccp
central-manager address 10.10.10.10
cms enable
Best Practice
In such scenario with an internal module following are usually advised:
"ip wccp 61 redirect in" the LAN interface.
"ip wccp 61 redirect in" on the WAN one.
"ip wccp redirect exclude in" on the internal interface between the WAAS and the router.
That way, we are sure that no loops are created because of the WCCP redirection.
Verify
The "sh wccp routers" command will display routers seen and not seen by this WAE.
WAE#sh wccp routers
Router Information for Service: TCP Promiscuous 61
Routers Configured and Seeing this File Engine(1)
Router Id Sent To Recv ID
192.168.10.1 10.1.1.1 0009B9A6
192.168.10.11 10.1.2.1 0009B942
Related Information
Password Recovery for WAAS installed on SRE module
Deploying WAAS on ISR G2 SRE Module
Best practice with WCCP flows for WAAS
