03-21-2015 07:34 PM - edited 03-01-2019 06:03 AM
A port channel bundles up to eight individual interfaces into a group to provide increased bandwidth and redundancy. You can also have upto sixteen ports in a port channel in active/standby setup. Port channeling also load balances traffic across these physical interfaces. The port channel stays operational as long as at least one physical interface within the port channel is operational. You can configure and run either static port channels or ports channels running the Link Aggregation Control Protocol (LACP). Cisco NX-OS does not support Port Aggregation Protocol (PAgP) for port channels.
With LACP, you can bundle up to eight interfaces in a channel group. You must enable LACP before the feature functions. Each system that runs LACP has an LACP system priority value. You can accept the default value of 32768 for this parameter, or you can configure a value between 1 and 65535. Each port configured to use LACP has an LACP port priority. You can accept the default value of 32768 for the LACP port priority, or you can configure a value between 1 and 65535. LACP uses the port priority with the port number to form the port identifier.
Entering the port channel displays following methods for load balancing.
switch(config)# port-channel load-balance ethernet ?
destination-ip Destination IP address
destination-mac Destination MAC address
destination-port Destination TCP/UDP port
source-dest-ip Source & Destination IP address (includes l2)
source-dest-ip-only Source & Destination IP addresses only
source-dest-mac Source & Destination MAC address
source-dest-port Source & Destination TCP/UDP port (includes l2 and l3)
source-dest-port-only Source & Destination TCP/UDP port only
source-ip Source IP address
source-mac Source MAC address
source-port Source TCP/UDP port
destination-ip :- Uses destination mac and destination IP to calculate the hash.
destination-mac :- Uses destination mac address to calculate the hash.
destination-port :- Uses destination mac, destination IP and destination port number to calculate the hash.
source-dest-ip :- Same as destination-ip but also includes source mac and IP address.
source-dest-ip-only :- Uses only the source and destination IP address for calculating the hash.
source-dest-mac :- Uses only the source and destination mac address for calculating the hash.
source-dest-port :- Same as destination-port but also includes source mac, IP and port number.
source-dest-port-only :- Uses only the source and destination port numbers for calculating the hash.
source-ip :- Same as destination-ip but instead uses source mac and IP address.
source-mac :- Same as destination-mac but instead uses source mac address.
source-port :- Same as destination-port but instead uses source mac, IP and port number.
On the Nexus 5000/6000 platforms, all FEXs will inherit the global hashing algorithm from the parent device.
On the Nexus 7000 platform, hashing algorithms can be assigned on a per FEX basis (all load balancing changes must be made from the Admin VDC).
For example:
N7K-A(config)# port-channel load-balance src-dst ip-l4port fex 134
Any FEX without a hashing algorithm configured with inherit the global hash. Making changes to the modular/global hash will not alter FEX specific hashing algorithms.
To verify the configuration applied you can use this command
N5K_A# show port-channel load-balance
On the Nexus 7000, the per FEX algorithm can be checked by appending the ‘fex <#>’ to the end of the command in the Admin VDC or the FEX’s respective VDC.
There are three modes to configure a Port Channel.
On : All static EtherChannels, that is, that are not running LACP, remain in this mode. If you attempt to change the channel mode to active or passive before enabling LACP, the device returns an error message.
Active : LACP mode that places a port into an active negotiating state, in which the port initiates negotiations with other ports by sending LACP packets.
Passive : LACP mode that places a port into a passive negotiating state, in which the port responds to LACP packets that it receives but does not initiate LACP negotiation.
vPC Status Down between Nexus 5000 and Directly connected Server
vPC Best Practices for Nexus 7000 and 5000
vPC Failover Scenarios and Troubleshooting Checklist
Load-balancing Algorithm for NX-OS Port Channels
the described loadbalancing methods above only apply to unicast, right ?
grtz
Thijs
bump
I would also like to know what Thijs asked. Does the load balancing algorithm only affect unicast traffic or does it also affect mcast/bcast?
PC load balancing is applying to ucast and mcast , PC dose not identify ucast or mcast. and bcast has no load balacing. you know its bcast.
N7K-C7010 after OS upgrade version 6.2.16 - > 7.3.(5)D1(1)
Only 1 of the 4 devices produced:
port-channel load-balance src-dst ip type srcdst-oxid fex all
And it cannot be deleted, why is this?
N7K-7010# show module
Mod Ports Module-Type Model Status
1 8 10 Gbps Ethernet XL Module N7K-M108X2-12L ok
2 8 10 Gbps Ethernet XL Module N7K-M108X2-12L ok
5 0 Supervisor Module-2 N7K-SUP2 active *
6 0 Supervisor Module-2 N7K-SUP2 ha-standby
9 48 1000 Mbps Optical Ethernet XL Modul N7K-M148GS-11L ok
10 48 1000 Mbps Optical Ethernet XL Modul N7K-M148GS-11L ok
Mod Sw Hw
1 7.3(5)D1(1) 3.3
