Sandeep Singh
Level 7
Level 7
Introduction
The Cisco NX-OS software consists of the kickstart image and the system image. The system image includes the software for the Cisco Nexus device and the Cisco Nexus Fabric Extenders (FEXs) that are connected to the switch. NX-OS supports a technology called In-Service Software Upgrade (ISSU) that allows a Cisco Nexus 5000 Series switches and any connected FEXs to be upgraded without any traffic disruption (with a brief control plane disruption). You can choose to do a disruptive upgrade, if one of the ISSU conditions are not met.
Problem
Trying to upgrade a Nexus 5596 switch but it fails. This can be checked using following command
Nexus5596.A2-C06# sh install all impact kickstart bootflash:n5000-uk9-kickstart.6.0.2.N2.3.bin system bootflash:n5000-uk9.6.0.2.N2.3.bin
Verifying image bootflash:/n5000-uk9-kickstart.6.0.2.N2.3.bin for boot variable "kickstart".
[####################] 100% -- SUCCESS
Verifying image bootflash:/n5000-uk9.6.0.2.N2.3.bin for boot variable "system".
Verifying image type.
Extracting "system" version from image bootflash:/n5000-uk9.6.0.2.N2.3.bin.
[#                   ]   0% -- FAIL. Return code 0x404F0003 (SRG file not present/cannot be opened).
Pre-upgrade check failed. Return code 0x40930012 (SRG extraction failed).
Getting error SRG file not present and SRG extraction failed.
Software and Hardware Versions
Software
  BIOS:      version 3.6.0
  loader:    version N/A
  kickstart: version 6.0(2)N1(2)
  system:    version 6.0(2)N1(2)
Hardware
  cisco Nexus 5596 Chassis ("O2 48X10GE/Modular Supervisor")
  Intel(R) Xeon(R) CPU   with 8262944 kB of memory.
  Processor Board ID FOC17xxxxx
  Device name: Nexus5596.A2-C06
  bootflash:    2007040 kB
Checks before Installation
If you are doing an ISSU you should do certain sanity checks to ensure that the system is ready and to understand the impact of ISSU:
  • Use the show incompatibility command to verify that the target image is feature-wise compatible with the current image.
  • Use the show logging level command to ensure that the severity level for all processes is set to 5 or below.
  • Use the show install all impact command to identify the upgrade impact.
  • Use the show fex command to verify that all the FEXs are online.
  • Use the show vpc role command to verify the vPC switch role in a vPC topology.
Description
When a software upgrade is done on a Cisco Nexus switch, it copies the upgrade image in the flash and decompress it. The error "SRG extraction failed" means a failure while decompressing the upgrade image file. If the image file is not decompressed properly the upgrade process can not continue.
Use command "show system internal dir /var/tmp" to check for unwanted files also check for overall utilization of the flash.
Nexus5596.A2-C06# sh system internal flash
Mount-on                  1K-blocks      Used   Available   Use%  Filesystem
/                            409600     72812      336788     18   /dev/root
/proc                             0         0           0      0   proc
/post                          2048         4        2044      1   none
/var                         409600     72812      336788     18   none
/sys                              0         0           0      0   none
/isan                       1536000    765456      770544     50   none
/var/tmp                     307200       100      307100      1   none
/var/sysmgr                 1024000         4     1023996      1   none
/nxos/tmp                     40960        32       40928      1   none
/var/sysmgr/ftp              409600        68      409532      1   none
/var/sysmgr/ftp/cores        102400         0      102400      0   none
/callhome                     61440         0       61440      0   none
/dev/shm                     524288    284536      239752     55   none
/volatile                    153600         0      153600      0   none
/debug                        20480         0       20480      0   none
/dev/mqueue                       0         0           0      0   none
/debugfs                          0         0           0      0   nodev
/mnt/plog                     49024      1360       47664      3   /dev/mtdblock2
/mnt/cfg/0                   113794      4347      103572      5   /dev/sda5
/mnt/cfg/1                   113794      4347      103572      5   /dev/sda6
/var/sysmgr/startup-cfg      409600      2860      406740      1   none
/dev/pts                          0         0           0      0   devpts
/mnt/pss                     113802      5402      102524      6   /dev/sda4
/bootflash                  1612212    562324      967988     37   /dev/sda3
/proc/bus/usb                     0         0           0      0   none
Nexus5596.A2-C06# show system internal dir /var/tmp
./         680
../         260
mysrg         1984
upgrade_status_file            1
mylogs          760
bootloader_ver            0
m2rib_ascii.3623           34
_clis_parse_tree_.log         2706
fcoe_mgr_init.log        15815
CSCub19397_debug          237
fcoe_mgr            0
fc-pcm-log-4225          757
fabric_start_cfg_mgr.log          761
issu_helper.log          224
stp.log.1         4316
fwm1.out            0
ntpd_1            0
ntp_client_1            0
igmp_restart.log            0
cfs_mac.log          332
radius_debug.log          232
security_stderr           77
security_stdout            0
aaa_debug.log          519
lcc.log          694
security_debug.log          647
cmp_slot_id.1            0
mvsh.3260            0
lockcisco            0
.flexlm/          60
logs@          20
first_setup.log         4745
boot_uptime.log           56
vsh/          40
Resolution
To resolve this issue free up the space in flash directory. Follow these steps:
1. In flash directory /var/tmp try to delete all .log files as these files are not required by the system. Do not delete any directory.
2. Check if there is an open telnet session locking a file in bootlash. The filename is "sup_params_info" and will be present in /var/tmp directory. Delete this file and see if you can continue with upgrade.
3. If still you are getting the error when trying to upgrade; reload the switch.
This document is created from following discussion
https://supportforums.cisco.com/discussion/12060756/nexus-5596-upgrade-602n23-failure
Related Information
NX-OS Software Upgrade and Downgrade Guide
Configuration Rollback Overview and Guidelines
