David Kosich
                                                      Borrowed with permission from Francis Guillier, Cisco technical marketing engineer (TME)
hitesh.lodhi
why not...
LJ Gabrillo
Level 5
Level 5
As far as my research goes,
Nexus 5k supports dual-homing in vPC setup
Nexus 7k still does NOT support it
See link to where I found it: CLICK ME   -Cisco Documentation
LJ Gabrillo
Level 5
Level 5
Okay hahaa this is just in, just last week June 18, 2015
Cisco released this Nexus 7k firmware version: v7.2(0)D1(1)
THIS NOW SUPPORTS DUAL-HOMING HAHA ^_^
Rajeshkumar Gatti
hitesh.lodhi
link missing , so what is the final outcome...does 7k support dual home or not.
dan.ryan28
It's in the 7.2 release notes:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/7_x/nx-os/release/notes/72_nx-os_release_note.html#pgfId-1174959
"FEX AA features
Fabric Extender (FEX) is a pass-through/mux device designed to provide top of rack or end of line connectivity for servers/hosts. Currently FEX can be connected to only one Cisco Nexus 7000 series switch. If the switch goes down, FEX loses connectivity to the network. Hence all the singly connected hosts via the FEX also lose connectivity to the network. To solve this problem, FEX can be connected to two Cisco Nexus 7000 series switches in Active-Standby mode or Active-Active mode (vPC). We choose the Active-Active solution because vPC provides seamless switchover and faster convergence in case of switch failure. Moreover, traffic is also sprayed across both switches providing full utilization of bandwidth."
Rajeshkumar Gatti
Please reference this post. Broken link has been updated.
manojk6
Nexus 5K Support Dual-homing
