09-26-2016 05:59 AM - edited 03-01-2019 06:05 AM
Customer needs to use the same VLAN for two different EPGs? Encap already in use fault? PPV is for you!
The output below from ELTMC shows two sets of BD/EPG. the FD_VLAN for 373 is shown twice but its important to note the Fabric_encap is unique. This fabric_encap is generated based on the VLAN pool/namespace. Thats why its required to have a unique VLAN pool, so that the fabric_encap VXLAN/vnid is unique.
module-1# show system internal eltmc info vlan brief
VLAN-Info
VlanId HW_VlanId Type Access_enc Access_enc Fabric_enc Fabric_enc BDVlan
Type Type
1 1 BD_CTRL_VLAN 802.1q 4094 VXLAN 16777209 0
4 13 BD_EXT_VLAN 802.1q 99 VXLAN 15499165 4
5 2 BD_VLAN Unknown 0 VXLAN 15761386 5
8 3 BD_VLAN Unknown 0 VXLAN 15531930 8
9 16 FD_VLAN 802.1q 2265 VXLAN 9402 8
10 4 BD_VLAN Unknown 0 VXLAN 15105997 10
11 17 FD_VLAN 802.1q 2261 VXLAN 9398 10
12 5 BD_VLAN Unknown 0 VXLAN 16351141 12
13 18 FD_VLAN 802.1q 2259 VXLAN 9396 12
14 14 BD_EXT_VLAN 802.1q 2198 VXLAN 15695749 14
15 19 FD_VLAN 802.1q 2262 VXLAN 9399 8
16 6 BD_VLAN Unknown 0 VXLAN 16351138 16
17 20 FD_VLAN 802.1q 2255 VXLAN 9392 16
18 7 BD_VLAN Unknown 0 VXLAN 15925209 18
19 21 FD_VLAN 802.1q 2260 VXLAN 9397 18
20 8 BD_VLAN Unknown 0 VXLAN 16056263 20
21 22 FD_VLAN 802.1q 2263 VXLAN 9400 20
22 15 BD_EXT_VLAN 802.1q 2104 VXLAN 14811122 22
25 9 BD_VLAN Unknown 0 VXLAN 16056264 25
26 10 FD_VLAN 802.1q 375 VXLAN 9811 25
27 23 BD_VLAN Unknown 0 VXLAN 16416668 27
28 24 FD_VLAN 802.1q 373 VXLAN 9809 27
29 11 BD_VLAN Unknown 0 VXLAN 16121791 29
30 25 FD_VLAN 802.1q 374 VXLAN 9810 29
31 12 BD_VLAN Unknown 0 VXLAN 16187318 31
32 26 FD_VLAN 802.1q 390 VXLAN 9826 31
35 31 FD_VLAN 802.1q 1100 VXLAN 8392 5
42 32 BD_VLAN Unknown 0 VXLAN 14942179 42
43 33 FD_VLAN 802.1q 2195 VXLAN 8592 42
45 34 BD_VLAN Unknown 0 VXLAN 16416669 45
46 35 FD_VLAN 802.1q 373 VXLAN 10592 45
module-1#
Note: BD1/EPG1 has encap vlan-373 and uniquely identified in the fabric as BD-16416668/EPG-9809. BD2/EPG2 has encap vlan-373 again BUT the fabric_encap for the BD/EPG is different than before BD-16416668/EPG-10592
Also interesting to note is the HW column. This shows the front panel ASIC VLAN and how it is translated uniquely.
module-1# show system internal eltmc info interface e1/25
IfInfo:
interface: Ethernet1/25 ::: ifindex: 436305920
iod: 54 ::: state: up
External: FALSE
NorthStar Info:
Mod: 0 ::: Port: 25
port_layer: L2 ::: fabric_port: 0
port_mode: trunk ::: native_vlan_id: 0
switchingSt: enabled ::: speed: 10000
Storm Ctrl Info:
Type: Percent
Stm_rate: 100.000000 ::: Stm_burst: 100.000000
Stm_rate(Mbps): 10000.000000 ::: Stm_burst(Mbps): 10000.000000
Stm_rate(toks): 6250 ::: Stm_burst(toks): 65535
Stm_Pol_Apply: 0
xlate_l2_classid_unset: 0
vlan_bmp: 25-32
vlan_bmp_count: 8
acc_vlan_bmp: 373-375,390
acc_vlan_bmp_count: 4
scope(0:G, 1:L): 1 ::: class_id:: 4
mac_limit_reached: 0 ::: mac_limit: 0
port_sec_feature_set: 0 ::: mac_limit_action: 0
NorthStar Info:
pc_mbr_idx: 11 ::: dest_learn_port: 12
dest_encap_idx: 56
BCM Info:
[SDB INFO]:
iod: 54
pc_if_index: 0
fab_if_index: 0
sv_if: 0
svp: 0
bcm_l3_eif: 0
internal_vlan: 0
encap_vlan: 0
mod: 0
port: 25
non_byp_mod: 0
non_byp_port: 25
ns_lrn_port: 12
v6_tbl_id: 0
v4_tbl_id: 0
router_mac:00.00.00.00.00.00
unnumbered: 0
bcm_trunk_id: 0
tunnel_mp st: 1096941571
tep_ip st: 1096941571
ip_if_mode: 0
bcm_vrf_id: 0
Overlay idx: 0
External: FALSE
FP Entries
ifp_port_mask_m0: 666
module-1#
With the output above we queried ELTMC again but this time for information on how the interface is programmed. Highlighted we see the scope field is set to local. This allows the front panel ASIC to have extra translations as well as have ACI classify traffic with (vlan, port)
The moquery below for the concrete vlan "vlanCktEp" and filtered by "encap==vlan-373" shows two objects on that particular leaf. Highlighted are the duplicated encap vlan and unique DN and EPG DN as well
fab1-p1-leaf1# moquery -c vlanCktEp -f 'vlan.CktEp.encap=="vlan-373"' Total Objects shown: 2 # vlan.CktEp encap : vlan-373 adminSt : active allowUsegUnsupported : 0 childAction : classPrefOperSt : encap createTs : 2016-09-06T08:45:52.000-04:00 ctrl : policy-enforced dn : sys/ctx-[vxlan-2326529]/bd-[vxlan-16416668]/vlan-[vlan-373] enfPref : hw epUpSeqNum : 0 epgDn : uni/tn-dpita-tenant/ap-dpita-AP/epg-dpita-EPG1 excessiveTcnFlushCnt : 0 fabEncap : vxlan-9809 fwdCtrl : mdst-flood hwId : 24 id : 28 lcOwn : local modTs : 2016-09-06T08:45:54.308-04:00 mode : CE monPolDn : uni/tn-common/monepg-default name : dpita-tenant:dpita-AP:dpita-EPG1 operSt : up operStQual : unspecified operState : 0 pcTag : 16391 proxyArpUnsupported : 0 qosPrio : unspecified qosmCfgFailedBmp : qosmCfgFailedTs : 00:00:00:00.000 qosmCfgState : 0 rn : vlan-[vlan-373] status : type : ckt-vlan vlanmgrCfgFailedBmp : vlanmgrCfgFailedTs : 00:00:00:00.000 vlanmgrCfgState : 0 # vlan.CktEp encap : vlan-373 adminSt : active allowUsegUnsupported : 0 childAction : classPrefOperSt : encap createTs : 2016-09-06T08:46:18.000-04:00 ctrl : policy-enforced dn : sys/ctx-[vxlan-2326529]/bd-[vxlan-16416669]/vlan-[vlan-373] enfPref : hw epUpSeqNum : 0 epgDn : uni/tn-dpita-tenant/ap-dpita-AP/epg-test-ppv excessiveTcnFlushCnt : 0 fabEncap : vxlan-10592 fwdCtrl : mdst-flood hwId : 35 id : 46 lcOwn : local modTs : 2016-09-06T08:46:19.964-04:00 mode : CE monPolDn : uni/tn-common/monepg-default name : dpita-tenant:dpita-AP:test-ppv operSt : up operStQual : unspecified operState : 0 pcTag : 49155 proxyArpUnsupported : 0 qosPrio : unspecified qosmCfgFailedBmp : qosmCfgFailedTs : 00:00:00:00.000 qosmCfgState : 0 rn : vlan-[vlan-373] status : type : ckt-vlan vlanmgrCfgFailedBmp : vlanmgrCfgFailedTs : 00:00:00:00.000 vlanmgrCfgState : 0 fab1-p1-leaf1#
Hi Dpita,
How did you manage to issue the
command? When I try, the system only lets me type
I'm running version 2.1.1(h) on the APIC, 12.1.1(h) on the 9Ks
RedNectar
This is a line card command. Use vsh_lc to enter this mode.
leaf1#
leaf1#
leaf1# vsh_lc
vsh_lc
module-1# show sys int eltmc info vlan br
Of course - I should have looked at the module-1# prompt!
Hello Daniel,
we have got the message "Encap Already Used in Another EPG" you mentionned at the beginning of this port; without apparent reason
I understand this might be solved by the PPV option you described above;
what I don't understand is why this message appears ;
we had a 1st UCS (UCS1) connected via VPC on 2 LEAFs 201 & 202, and using 1 static path encap vlan 11 on EPG11 : no problem
when adding a 2nd UCS (UCS2) also connected via another VPC on the 2 same LEAFs 201 & 202, and adding 1 static path encap for the same VLAN 11 on the same EPG1, we got this "Encap Already Used in Another EPG" message
any idea why such a message appears ?
thanks
HI,
Both VPC cannot have same encap unless the VPC port scope is local.Atleast 1 VPC has to be local in this case.Also,The two epgs should be in different BD's.Please configure as above and assign same vlan,you will not see the problem.
-Hrishi
Hi all,
Is there any disadvantages or extra limitations of PPV configuration or can we use it for all ports without concern?
Thanks. Regards.
You cannot have same vlan encap on 2 different EPGs if you are adding the same ports in each. Even with PPV turned on, this does not work. The static ports that you assign to both the EPGs have to be different. Verified this in the lab.
