on 05-23-2023 05:37 AM
Using BGP, we have the option to send community and extended community attributes with the prefixes that we advertise to BGP peers. These community attributes allow us to modify routing policies and dynamically alter the way we handle routed traffic. However, when a community attribute is misconfigured or doesn't adhere to industry standards, problems can occur. This document specifically explains what happens when the Router Mac extended community attribute (EVPN extended community sub-type 0x03) is sent with an IPv4 address family prefix from an external BGP peer to an ACI fabric.
When the Router MAC extended community attribute is sent with an IPv4 AFI prefix from an external BGP peer to an ACI fabric, FIB and HAL misprogramming occurs on any leaf in the fabric that receives the route from the border leaf(s) via the internal MP-BGP process. This is because the RMAC extcommunity attribute belongs to the BGP L2VPN EVPN address family, and when it is injected into the BGP IPv4 address family, it gets rejected. This is due to a violation of rule 5.2 (Uniform-Propagation-Mode), which is described in the IETF document entitled, "EVPN Interworking with IPVPN". On page 15, item 4c, the specific issue is called out:
4. As discussed, Communities, Extended Communities and Large
Communities SHOULD be kept by the gateway PE from the originating
SAFI route. Exceptions of Extended Communities that SHOULD NOT
be kept are:
C. All the extended communities of type EVPN.
The gateway PE SHOULD NOT copy the above extended communities
from the originating ISF route to the re-advertised ISF route.
Link to document: EVPN Interworking with IPVPN
Below is an example of the problem using iBGP, however the problem is also seen with eBGP.
Topology Diagram:
Configure route-map on external BGP peer device (Router 1) and set the EVPN RMAC extcommunity attribute:
Router-1# show run | sec route-map
route-map RMAC permit 10
set extcommunity evpn rmac aaaa.bbbb.cccc
Under the BGP neighbor IPv4 address family configuration, configure BGP extended communities and configure the route-map in the outbound direction:
Router-1# show run bgp
<output omitted>
feature bgp
router bgp 65001
vrf example
router-id 2.3.0.2
address-family ipv4 unicast
network 192.168.20.0/24
neighbor 40.40.40.40
remote-as 65001
update-source loopback1
send-community extended
route-map RMAC out
Check the BGP status on BL 101:
leaf-101# show ip bgp 192.168.20.0 vrf example:example
BGP routing table information for VRF example:example, address family IPv4 Unicast
BGP routing table entry for 192.168.20.0/24, version 40 dest ptr 0xa0fec840
Paths: (1 available, best #1)
Flags: (0x80c001a 00000000) on xmit-list, is in urib, is best urib route, is in HW, exported
vpn: version 2725, (0x100002) on xmit-list
Multipath: eBGP iBGP
Advertised path-id 1, VPN AF advertised path-id 1
Path type (0xa96485b8): internal 0x18 0x0 ref 0 adv path ref 2, path is valid, is best path
AS-Path: NONE, path sourced internal to AS
192.168.20.20 (metric 5) from 192.168.20.20 (2.3.0.2)
Origin IGP, MED not set, localpref 100, weight 0 tag 0, propagate 0
Extcommunity:
RT:65001:2162688
COST:pre-bestpath:163:1879048192
Router MAC:aaaa.bbbb.cccc
***Notice that the router mac is present here.***
VNID:2162688
VRF advertise information:
Path-id 1 not advertised to any peer
VPN AF advertise information:
Path-id 1 advertised to peers:
10.0.216.65 10.0.216.66
Check RIB on CL 102:
leaf-102# show ip route 192.168.20.0 vrf example:example
IP Route Table for VRF "example:example"
'*' denotes best ucast next-hop
'**' denotes best mcast next-hop
'[x/y]' denotes [preference/metric]
'%<string>' in via output denotes VRF <string>
192.168.20.0/24, ubest/mbest: 1/0
*via 10.0.210.70%overlay-1, [200/0], 00:00:43, bgp-65001, internal, tag 65001, rwVnid: vxlan-2162688
recursive next hop: 10.0.210.70/32%overlay-1
***Notice that we have the route here and our next-hop address is correct (showing the TEP IP of BL 101). Also, notice that there is an rwVnid entry here.***
leaf-102# acidiag fnvread | grep 101
101 1 leaf-101 <output omitted> 10.0.210.70/32 leaf active 0
Check FIB on CL 102:
module-1(DBG-elam-insel6)# show forwarding route 192.168.20.0 vrf example:example
ERROR: no longest match in IPv4 table 0xf5df36b0
***No entry is present.***
Check HAL table on CL 102:
module-1(DBG-elam-insel6)# show platform internal hal l3 routes | grep 192.168.20.0
Pings from EP (Host 1) to host in external network coming from external BGP peer (192.168.20.20):
Host-1# ping 192.168.20.20 vrf example
PING 192.168.20.20 (192.168.20.20): 56 data bytes
Request 0 timed out
Request 1 timed out
Request 2 timed out
Request 3 timed out
Request 4 timed out
--- 192.168.20.20 ping statistics ---
5 packets transmitted, 0 packets received, 100.00% packet loss
***No connectivity.***
Check ELAM on CL 102:
leaf-102# vsh_lc
module-1# debug platform internal roc elam asic 0
module-1(DBG-elam)# trigger reset
module-1(DBG-elam)# trigger init in-select 6 out-select 0
module-1(DBG-elam-insel6)# set outer ipv4 src_ip 192.168.10.10 dst_ip 192.168.20.20
module-1(DBG-elam-insel6)# start
module-1(DBG-elam-insel6)# stat
ELAM STATUS
Asic 0 Slice 0 Status Armed
Asic 0 Slice 1 Status Triggered
module-1(DBG-elam-insel6)# ereport
Python available. Continue ELAM decode with LC Pkg
ELAM REPORT
<output omitted>
Lookup Drop
LU drop reason : UC_PC_CFG_TABLE_DROP
***Notice the drop vector here.***
The solution is to stop sending the Router Mac extended community attribute with an IPv4 address family prefix from an external BGP peer to an ACI fabric.
Remove the previously configured route-map and stop sending extended communities from the external BGP peer device (Router-1). Removing either one of these configs, or both, will work:
<output omitted>
feature bgp
router bgp 65001
vrf example
router-id 2.3.0.2
remote-as 65001
BGP routing table entry for 192.168.20.0/24, version 46 dest ptr 0xa0fec840
vpn: version 2731, (0x100002) on xmit-list
Extcommunity:
RT:65001:2162688
***Notice that no router mac is present here.***
VNID:2162688
*via 10.0.210.70%overlay-1, [200/0], 00:00:06, bgp-65001, internal, tag 65001
***Notice that no rwVnid entry is present here.***
Note: The absence or presence of an rwVnid entry alone does not determine whether the issue is occurring or not. In many cases, the rwVnid entry will get removed from the route in question once the issue is resolved. However, this is not always the case. Always check FIB and HAL tables to verify if the issue is resolved or not.
IPv4 routes for table example:example/base
Prefix | Next-hop | Interface/VRF | Additional Info
*192.168.20.0/24 10.0.210.70 overlay-1
***Notice that we have the route here and our next-hop address is correct (showing the TEP IP of BL 101).***
Route Class-id:0x0
Policy Prefix 0.0.0.0/0
| 4662| 192.168.20.0/ 24| UC| 686| 20601| TRIE| a5| 5/ 0| 60a5|A| 8443| 86b6| ef5| 1/ 2| a5| 0| 0| f| 3| 0| 0| 1| sc,spi,dpi
***Notice that we have an entry here and it's in the correct VRF.***
module-1(DBG-elam-insel6)# hex 4662
0x1236
module-1(DBG-elam-insel6)# show platform internal hal l3 vrf pi
| -- TOR -- | - Spine - | ACL | |
Vrf Hw I I Vrf | SB NB | Proxy ACI | Ing Egr | vpn |
VrfId Name VrfId I S Vnid | BDId BDId | Ou Bd Enc | Lbl Msk Lbl Msk | lbl |
26 example:example 1236 0 0 210000 0 0 0 1 0 0 0 0 0
64 bytes from 192.168.20.20: icmp_seq=0 ttl=252 time=1.043 ms
64 bytes from 192.168.20.20: icmp_seq=1 ttl=252 time=1.292 ms
64 bytes from 192.168.20.20: icmp_seq=2 ttl=252 time=1.004 ms
64 bytes from 192.168.20.20: icmp_seq=3 ttl=252 time=0.769 ms
64 bytes from 192.168.20.20: icmp_seq=4 ttl=252 time=1.265 ms
5 packets transmitted, 5 packets received, 0.00% packet loss
round-trip min/avg/max = 0.769/1.074/1.292 ms
***Connectivity is there.***
ELAM on CL 102:
leaf-102# vsh_lc
ELAM STATUS
ELAM REPORT
<output omitted>
Lookup Drop
LU drop reason : no drop
***Traffic forwards correctly.***
This behavior is also documented in this defect: CSCvx28929
Thanks @mrichinfinite
