Monica Lluis
Level 9
Level 9
Introduction
Fibre  Channel Over Ethernet (FCoE)
1. Does NX-0S 5.0 run  NPIV?
Yes, it is supported in NX-OS 5.0. Nexus 5000  platform supports N port identifier virtualization (NPIV) and N-Port  Virtualization(NPV) since NX-OS 4.0 version. Nexus 5K supports two  modes. By default, Cisco Nexus 5000 and 5500 Series switches operate in  fabric mode, in this mode switch provides standard FC switching  capability and features. Second mode is NPV, in NPV mode Nexus 5K  switches relays all the traffic from server-side ports oto the core  switch.(NPIV enabled switch). The core switch provides F port  functionality and all FC switching capabilities.
2. Is  FCoE between data centers possible?
Yes, FCoE between  Data Centers is possible. VE Ports allow you to build multi-hop FCoE  fabrics by interconnecting multiple FCF, VE port functions as a Fibre  Channel E-port running on top of a lossless Ethernet fabric. The maximum  distance between two Cisco Nexus 5000 Series switches is 3000m for FCoE  (lossless Ethernet) traffic with NX-OS 5.0(2)N1.1. It can be enabled  using the pause no-drop buffer-size buffer-size pause-thresholdxoff-size resume-threshold xon-size command in QOS configuration. Here are the maximum distances:
Nexus  55xx to Nexus 55xx - 3km
Nexus 50x0 to Nexus 50x0 - 3km
Nexus  50x0 to Nexus 55xx - 3km
Nexus 55xx to Nexus 2232 - 300m
Nexus  50x0 to Nexus 2232 - 300m
More on http://www.cisco.com/en/US/partner/docs/switches/datacenter/nexus5000/sw/qos/502_n2_1m/Cisco_Nexus_5000_Series_NX-OS_Quality_of_Service_Configuration_Guide_Rel_502_N1_1_chapter3.html#task_81ABFBE86A57475DA65966D5C9BC24A1
3.  Can you explain the vlan trunking channels a little bit more?
We  support Virtual LAN on top of the Fibre channel Over ethernetwork. So  trunking means we carry different Virtual LAN altogether in one ISL. And  the same on FCOE we also support Virtual SANs and can carry multiple  virtual SANs on one isl. In turns of multi-hop FCOE we will see that we  could carry multiple virtual LAN and virtual SANs together.
4.  Can FCoE be used with UCS?
Yes. In latest UCS 1.4  release, you can directly connect FCoE targets to the Fabric  Interconnect ports. Also on UCS system we have FIP cabable (Gen2) CNAs  and Pre-FIP (Gen1) CNAs running on the blades that utilizes FCoE between  blades and Fabric Interconnect. If you would like to extend Fabric  Interconnect connectivity with VE ports and connecting them to Nexus 5K  switches in terms of running multi-hop FCoE, we don't support this on  the UCS software yet.
5. What is the next data rate after 10Gig  for FC? is it 16Gig? When will it be supported?
After  the 10Gig model the discussion are in 12Gig and 16Gig. If you are asking  Cisco will be supporting 16gig FC, yes we will be supporting it and we  will have products that will be supporting 16gig FC.
6.  Is there a limit on the number of hops that can be made in a multihop  environment/design?
The limit is 7 actually. You can  have upto 7 FCoE hops that are tested and supported by Cisco. If there  is any requirement to suppoprt more than 7 hops, that can be tested by  Cisco. Please contact your Cisco Account Manager if you require more  than 7 hops.
7. Can we configure multiple COS values  for PFC ?
Yes, if you are asking you can use different  COS values for PFC. PFC uses the IEEE 802.1p CoS values in the IEEE   802.1Q VLAN tag to differentiate up to eight CoSs that can be subject  to  flow control independently. So on Nexus 5K,by default we have 8  lanes , 8 qos-groups. Qos 6 and Qos 7 are reserved for control plane  trafic and the rest 6 qos-groups can be assigned to drop-class or  no-drop-class. By default FCoE is assigned COS 3.
8.  What if we want to trunk multiple data vlans to a service thats running  ESXi for example do we still need to configure trunking on switch ports?
Yes  if you want to carry multiple data VLANs on ESXi , we definitely need  to configure trunking. Also another reason if you want to use FCoE, Fiber  Channel over Ethernet Initialization Protocol (FIP) uses the native  VLAN and therefore all FCoE links should be trunked to carry the FCoE  VLAN as well as the native VLAN.
9.  What is the difference between CEE and a DCE?
CEE is  the Converged Enhanced Ethernet. The CEE authors group was an informal  group of companies that submitted the initial proposals of PFC , ETS and  DCBX to the IEEE DCB working group.DCE is a Cisco term that describes  the architectural collection of ethernet extensions based on open  standards. DCE includes support for the ethernet extensions found in EEE  DCB.
10. How is the FCOE license activated on the  Nexus 5000 or 5500 series?
There is an option in the  Nexus 5000 called storage service license which is activated when it is  shipped from Cisco. When ordered as a seperate line card item an  activation key and the procedure for activating the code is delivered in  an envelope. Because this is always present and only activation is  needed and any Nexus 5k will automatically initiate the 120 days  temporary license for a storage protcol service from the first use of FC  or FCoE command.
11. Is FCOE IP Routable?
No, there is no Ip layer in FCoE. FC-BB-5 contains FCIP that  is "IP-routable". FCoE is FC-routable. FCoE switches may forward FC  frames across different Ethernet Clouds, FCoE switches may forward FC  frames over the Internet using FCIP.
12. Do I need to  enable Jumbo frames for FCOE?
Yes. You need to enable  jumbo frames because the FC payload is 2,112  bytes and enabling jumbo  frames will keep FCoE traffic from being fragmented. On Nexus 5K, we  have a pre-defined Class of Service (CoS) to be FCoE, which is by  default has the value 3. Within this CoS, the MTU size it set to 2158.
13.  Can you advise on any resources for FCOE where I can read more about  them?
You can refer the book “I/O  Consolidation in the Data Center” by Silvano Gai, Claudio DeSanti
You  can also visit the following resources:
Unified  Fabric
Fibre Channel over Ethernet  (FCoE)
IEEE 802.1  Data Center Bridging – White Papers
http://www.fcoe.com & FC-BB-5  Standard http://www.fcoe.com/09-056v5.pdf
Nexus  5000 Troubleshooting Guide
14. Can I use multiple  classes of service for FCoE?
Yes you can use multiple  classes of service for FCoE. We have 8 lanes, 8 QOS-groups. 6 and 7 are  reserved for control plane traffic that is used by the system.  That  leaves us 6 qos-group to use. One of the 6 qos-groups is pre-defined as  drop class and it is class-default(drop class) and that leaves us 5  qos-groups. In the remaining 5 qos-groups, only 4 can be configured as  "no-drop" and one of these could be FCoE.
15. Did  Cisco produce interoperability testing results with various vendors  (SAN, CNA adapters) ?
Yes we have the interoperability  matrix which we published on CCO Cisco.com.
http://www.cisco.com/en/US/partner/docs/switches/datacenter/mds9000/interoperability/matrix/Matrix7.html
We  try to certify, different Storage, different CNAs, different O/S and  different NX-OS versions. Also most of the OSM vendors publish their  interoperability matrixes in their own web sites.
16.  Can the concept and purpose of  Worldwide name can be briefy explained?
A World Wide Name (WWN) is a unique identifier which  identifies a particular Fibre Channel target, Each WWN is an 8 byte  number derived from an IEEE OUI and vendor-supplied information.
  • Original  format: addresses are assigned to manufacturers by the IEEE  standards  committee, and are built into the device at build time,  similar to an  Ethernet MAC Address.  The first 2 bytes are either hex 10:00 or 2x:xx  (where the x's are  vendor-specified) followed by the 3-byte vendor  identifier and 3 bytes  for a vendor-specified serial number
17.Which  CNA types are supported on Nexus 5000 and Nexus 2232PP?
We  have two flavours of Nexus 5K switches.They are Nexus 55xx and Nexus  5010/5020. On Nexus 5010/5020 we support Gen1 and Gen2 CNAs.
On  Nexus 55xx and Nexus 2232PP we only support Gen2 CNAs such as  QLE814x/QLE815x, Emulex One Connect...
18. What are the  requirements of FCOE?
You will need a lossless  ethernet network that will support FCoE, to build this network minimum  requirement is to have a Fibre Channel Forwarder (FCF switch) ,  host/server that has CNA installed and a FC or FCoE target that is  providing the access to the block storage for the server.
19.  Can you explain a little background about FC and ISCSI, and the  differences between FCoE and ISCSI? I've never had the need for FC, so  it's a different world with "credits" for me.
FC and  iSCSI share the same SCSI stack (to some extent), there are some  differences in the protocol stacks. FC is generaly used for tier-1 apps  so will FCoE by extension. iSCSI however is also seeing attraction in  that area.
20. I would like to know the difference  nowdays between ISCSI and FCoE as I have never had the need for FC in  the old days.
The iSCSI protocol can be implemented in  networks that are  subject to  packet loss, and iSCSI can run over 1  Gigabit Ethernet (1GbE). FCoE   requires 10 Gigabit Ethernet (10GbE) and  a lossless network with  infrastructure  components that properly  implement pause frame requests  and per-priority pause  flow control  (PFC) based on separate traffic  classes that map to different   priorities. The idea behind PFC is that  during periods of congestion,   high-priority traffic is allowed to  continue while lower-priority  traffic is  paused.
    Your 10GbE switches will need DCB  support for FCoE, including a   range of enhancements for classes of  service, congestion control, and   management. FCoE also requires Jumbo  Frames because the FC payload is  2,112  bytes and cannot be broken up;  iSCSI does not require Jumbo  Frames.
21. Do you know the  difference for the ethernet header between ISCSI and FCoE ? Could this  be an advantage for one of the protocols?
iSCSI has a TCP  overhead contributing to both the size of frame and also operational  inefficiencies that come with TCP retransmissions. There maybe benefits  to iSCSI in an ethernet loss-less environment as these retransmissions  are eliminated.
22.  Does FCoE (in general) support by all SAN vendors (for their own  proprietary modes), or do their gears need to run in interop mode?
It's  important to remember that FCoE *is* FC. It uses the exact same  protocol services as FC. Once a FCoE switch decapsulates the FC from the  Ethernet Frame, it is FC, and is handled by SAN vendors as a FC frame.  See the UNH Plugfest information at http://fibrechannel.org for  interoperability tests.
23. Does Cisco have any  multi-hop FCoE products?
Cisco currently has multi-hop FCoE  in the Nexus 5000 series of switches. Additionally, the Nexus 7000 and  MDS 9500 series Director switches have announced multihop capability;  watch for further information very soon.
24. Is CEE  still active ?
I hope I understand your question properly.  The DCB standards are built on what CEE defined originally. Cisco  switches abide by both standards.
25. What is the  typical uplink oversubscription on Fiber Channel switches ? If the  oversubscription cannot be avoided, does it mean FCoE must be deployed  with DCB together to avoid FC packets being dropped?
DCB is an  absolute requirement for FCoE. The links *need* to be loss-less before  it can even be considered for FC traffic as storage applications are  generally intolerant of loss. Regarding O/S, every organisation is  different and a value is chosen based on their tolerances. We have seen  4/1 over subscription to up to 15/1. When designing the storage network  the link O/S should be considered as well as the internal switch  hardware O/S however the latter is generally lower so not a bottleneck  but needs to be considered. This O/S is platform specific and changes in  accordance to the HW.
26. What is the aggregate encap/decap rate  of FCF inside the switch, like Nexus 5K?
I assume the  question is if the process of de-encap/re-encap FC-to-FCoE causes a  performance hit, and that is not the case since packets are parsed and  modified as they are transmitted to xbar on their way to egress  regardless of protocol type.That all happens at speeds much faster then  any input device can forward frames in,or receive frames out.
27.  Does the default QoS setting imply I/O consolidation would apply only  to servers running FCoE or below? how does it relate to the trend of  server consolidation, where I/O rate will get higher and higher as more  VMs are created?
The QoS setting (negotiated) sets up  the adjacent neighbors so that they can have a loss-less ethernet  conversation. The packets are tagged with a CoS which indicates the  Virtual Lane they ough to be in. In your case where I/O rates are  increasing due to VM adoption, if the host is tagging these packets as  loss-less with the correct CoS marking, then the frames are transmitted  with those capabilities and the switch treats them as such. However you  only ever have the 10G link offered. This QoS setting doesn't affect the  increasing I/O rates.
28. Based on slide #51. "Trunking is not  required on the host driver - all FCoE frames are tagged by the CNA."  what about if we want to trunk multiple data VLANs to the servers  running ESXi for example? do we still need to configure trunking on the  switch ports?
Yes, we need to configure "switchport  trunk" since Fiber Channel over Ethernet  Initialization Protocol (FIP) uses the native VLAN and therefore all  FCoE links should be trunked to carry the FCoE VLAN as well as the  native VLAN.
29. Can you explain what you meant  by multihop extending beyond the access?
Up until now,  you could connect FCoE from the server (using CNA) to an access switch.  With Multihop FCoE as defined by FC-BB-5 working group of T11 we can  extend FCoE beyound the access switch (via an ISL) to other switches and  perhaps into the SAN core. You can now build Ethernet based SAN rather  than a FC only SAN.
30. Is it possible carry FCoE  traffic across fabricpath cloud?
At this point in  time, no. Currently ethernet traffic and FCoE is handled on their own  respective VLANs, which means that you can apply FabricPath to the  Ethernet VLAN. FCoE uses FSPF for its forwarding mechanisms.
31.  Do I understand correctly ISL, so DOT1Q trunks are a no go?
It  is 802.1q , please have a look at the frame formats for FCoE and FIP in  the FC-BB-5 standard page 126.
http://www.t11.org/ftp/t11/pub/fc/bb-5/09-056v5.pdf
32.  How would you connect a 3rd party blade switch (FCoE enabled) to Cisco  Nexus infrastructure? Do i need to do multi-hop FCoE design?
At  this moment, there is no interoperability with the third party Blade  switches.
33. Can you elaborate a little on how zoning  is implemented in the N5K please? I understand that zoning cannot be  configured directly on the N5K but has to be downloaded from a SAN  switch, is this undertanding correct?
You can zone on  the N5K. It's per VSAN. Zoning is distributed to all the switches  connected in that VSAN. Zoning is a security feature which limits the  ports which are participating in the SAN. If the Nexus 5K switch is  running in NPV mode, the zoning must be distibuted from the core NPIV  enabled switch.
34. Referring to slide 54, if I  understand correctly, you can still have more than one link aggregated  into single logical link for both FCoE and LAN... just not through the  same logical link?
That's correct VE_ports can be  configured between two switches using a single port-channel or multiple  individidual links. To keep the SAN A and SAN B isolation, we have to  carry FCoE and LAN traffic with different port-channels.
35.  Is Nexus 2K supporting FCoE?
There are many flavors  of Nexus 2Ks (FEX). Only Nexus 2232PP supports FCoE on 10GE host ports  with NX-OS 4.2(1)N1 and higher releases.
36. Is there  is any training or course certification leading to FCoE  Knowledge ?
As  of now we dont have any certification for FCoE with Cisco or any other  vendor. These certifications will be launched very soon.
testing the issue reported by Tomas De Leon
