A very warm hello to all,
I would like to inform us all about the bug - CSCuq40526
KVM Does Not Launch After Upgrade to 2.0(1b)
In the Java console you will see the following error: Error:- Received Fatal Alert: handshake_failure avax.net.ssl.SSLHandshakeException: Received fatal alert: handshake_failure |
Solution:
Uncheck TLS 1.2 under advanced in Java settings
Bug Link: https://tools.cisco.com/bugsearch/bug/CSCuq40526/?reffering_site=dumpcr
the bug is fixed in 2.0(4c) firmware
Saurabh
