Summary:
From Vsphere Version 6.6 onwards Basic LACP is not supported, this post is to go through the steps required for the Enhanced LACP configuration when using VMM integration with ACI.
To configure Enhanced LACP please make sure that the Following Perquisites are met:
- VMM domain has been created and the DVS switch has been pushed to the Vcenter.
- VPC/Port-channel configuration on the ACI LEAF switches has been done, on the interfaces going towards the ESXI domain.
STEP1:
Configure the Enhanced LAG policy:
STEP 2:
Log in to the vSphere Client and verify that the LAG policy is being pushed on the VDS :
STEP 3:
Move the ESXI Host interfaces into the En-LACP policy:
a. Select host
b. Move Uplinks
c. Make sure that the uplink status is connected.
d. Verify on the LEAF switches that the VPC is up.
STEP 4:
EPG Association with the VMM domain
