Introduction
Cisco SM-SRE hosted by the Cisco ISR G2 have their own processors, storage, network interfaces, and memory that operate independently of the host router resources. This configuration helps to ensure maximum concurrent routing and application performance. Cisco SRE supports installing and uninstalling Cisco-authorized software, such as Cisco Unity Express, Cisco Application eXtension Platform (Cisco AXP), and Cisco IP Video Surveillance using Cisco IOS software commands and prevents unauthorized software and applications from running on Cisco SRE modules.
Basic Configuration for WAAS on SM
Once the image is installed, session to the module from the router:
ISR# service-module sm 1/0 session
After login configure the basic commands on the service module:
restore factory-default
device mode application-accelerator
hostname xyz
central-manager address a.b.c.d
interface GigabitEthernet 1/0
ip address w.x.y.z
primary-interface GigabitEthernet 1/0
ip default-gateway w.x.y.a
ip name-server
ip domain-name
ntp server
clock timezone
clear license Transport
license add Enterprise
cms enable
Related Information
Deploying WAAS on ISR G2 SRE Module
Deploy Cisco WAAS through a non Cisco Firewall
