Sandeep Singh
Level 7
Level 7
Introduction
Cisco UCS B-series blade servers sits inside the UCS chassis and are managed by UCS manager running on Fabric Interconnect. Cisco UCS C-series rack server are independent 1RU or 2RU size servers, which can be independently managed or via UCS FI.
UCS Blade Server vs Rack Server
The following table lists the differences between the Blade Servers and Rack Servers:
Blade Servers
Rack Servers
Sits into UCS blade chassis
Sits on a rack
Can’t operate independently. Requires UCS infrastructure
Can operate independently
Connects only to UCS Fabric Interconnect
Can connect to any Ethernet switch including UCS Fabric   Interconnect
Managed from the UCS Fabric   Interconnect by Cisco UCS Manager
Features Cisco Integrated Management Controller (CIMC) and   thus can be managed independently or from Cisco UCS Manager if connected to a   UCS Fabric Interconnect
Supports RAID 0 and 1 only
Supports built-in RAID 0 and 1 for SATA drives. RAID 0, 1, 5, 6, and 10 support through a PCIe LSI MegaRAID   Controller
Supports Gigabit Ethernet Mezz cards and Converged Network   Adapter Mezz cards
Supports Gigabit Ethernet PCIe cards, Converged Network   Adapter PCIe cards and Fibre Channel HBA PCIe cards.
Supports up to two front-accessible,   hot-swappable SAS drives for local storage
Supports up to 4 front-accessible,   hot-swappable, internal 3.5-inch SAS or SATA drives
No support for PCIe slots
Support for up to 2 PCIe 2.0 slots
No support for optical drive
Optional front panel optical drive for   CD and DVD media
nirmalissac
Great doc.. thanks alot.. +5
MD KAFINUZZAMAN
Thanks................
