Branden Varney
Introduction
 The Cisco Technical Assistance Center (TAC) often asks for Data Center Network Manager (DCNM) Tech-Supports when working to troubleshoot an issue involving DCNM. This document is meant to provide both a visual guide and the Command Line Interface (CLI) steps to gathering a DCNM tech-support.
Requirements
Gathering a Tech-Support Through Web User Interface (UI)
- Credentials to successfully log into DCNM Web UI with a Network Administrator role.
Gathering a Tech-Support Through Linux CLI
- Root user credentials or similar to successfully login to the Linux OS hosting DCNM.
Gathering a Tech-Support Through Microsoft Windows
- Credentials to successfully log into Windows
Components Used
Gather Tech-Support Through Web UI
- Firefox or Chrome
Gather Tech-Support Through Microsoft Windows
- Remote Desktop
Gather Tech-Support Through Linux CLI
- SSH client
Conventions
Refer to Cisco Technical Tips Conventions for more information on document conventions.
Gather Tech-Support Through Web Browser (DCNM 10.2.1 and Newer)
 Starting in 10.2.1 there is now the ability to gather a full tech-support through the DCNM Web UI.
This tech-support is the same type of server tech-support gathered in the Windows and Linux/OVA installs.
  • Login with an admin level user role through Chrome or Firefox.
The DCNM version number can be easily found in this screen above the Username promptThe DCNM version number can be easily found in this screen above the Username prompt
  • After successfully logging in select Administration > Logs.
Administration > LogsAdministration > Logs
  • Select Generate Techsupport.
Logs Landing PageLogs Landing Page
  • DCNM Tech-support will download to your default downloads location configured by your browser.
  • Upload the file to your case throug the Cisco.com case portal or by using the followng link:
Gather Tech-Support Through Windows (All Versions DCNM Window Installs)
Used when the DCNM Web UI is not available.
  • Login to Windows OS hosting DCNM.
  • Navigate to $INSTALLDIR/dcm/fm/bin/.
  • Right Click techsupport.bat and select Run as administrator
Default location: C:\Program Files\Cisco Systems\dcm\fm\binDefault location: C:\Program Files\Cisco Systems\dcm\fm\bin
  • A Command Prompt window appears and runs the batch file.
  • When the batch file completes, it will report the location and name of the generated tech-support.
    • The location is always $INSTALLDIR/dcm/fm/logs/
  Command Prompt Window Running techsupport.bat file.Command Prompt Window Running techsupport.bat file.
Gather Tech-Support Through Linux (All Versions DCNM Linux/OVA Installs)
  • Login to the Linux OS hosting DCNM.
  • Run $INSTALLDIR/dcm/fm/bin/techsupport.sh.
    • In DCNM OVA installations the direct path is /usr/local/cisco/dcm/fm/bin/techsupport.sh.
    • The location and name of the generated tech-support is indicated in the second to last line of the output.
# /usr/local/cisco/dcm/fm/bin/techsupport.sh
Server configuration file loaded: /usr/local/cisco/dcm/fm//conf/server.properties
Done setting System properties
log4j:WARN No appenders could be found for logger (fms.db).
log4j:WARN Please initialize the log4j system properly.
log4j:WARN See http://logging.apache.org/log4j/1.2/faq.html#noconfig for more info.
Done loading from db
Done sending show tech to server
0:Received
%  from server
1:Received dump written to /usr/local/cisco/dcm/fm/logs/fms_dump.9 from server
dumpFName: 'fms_dump.9'
adding /usr/local/cisco/dcm/fm/logs/fms_dump.9
Start compressing ....
Done with /usr/local/cisco/dcm/fm/logs/pm.log
Done with /usr/local/cisco/dcm/fm/logs/fmserver.log.7
Done with /usr/local/cisco/dcm/fm/logs/fmserver.log.2
Done with /usr/local/cisco/dcm/fm/logs/fmserver.log.3
Done with /usr/local/cisco/dcm/fm/logs/fmserver.log.9
Done with /usr/local/cisco/dcm/fm/logs/fmserver.log.4
Done with /usr/local/cisco/dcm/fm/logs/fmserver.log.5
Done with /usr/local/cisco/dcm/fm/logs/fmserver.log.1
Done with /usr/local/cisco/dcm/fm/logs/fmserver.log.10
Done with /usr/local/cisco/dcm/fm/logs/fmserver.log.8
Done with /usr/local/cisco/dcm/fm/logs/fmserver.log.6
Done with /usr/local/cisco/dcm/fm/logs/fm_web.log
Done with /usr/local/cisco/dcm/fm/logs/fms_snmp.log
Done with /usr/local/cisco/dcm/fm/logs/fms_snmp_trap.log
Done with /usr/local/cisco/dcm/fm/logs/fm_webusract.log
Done with /usr/local/cisco/dcm/fm/logs/fms_ws.log
Done with /usr/local/cisco/dcm/fm/logs/sme_accounting_log.2017-08-23-09-17-41.log
Done with /usr/local/cisco/dcm/fm/logs/smeAccounting.log
Done with /usr/local/cisco/dcm/fm/logs/sme_accounting_log.2017-07-23-12-00-00.log
Done with /usr/local/cisco/dcm/fm/logs/sme_accounting_log.2017-10-22-12-00-00.log
Done with /usr/local/cisco/dcm/fm/logs/sme_accounting_log.2017-06-18-12-00-00.log
Done with /usr/local/cisco/dcm/fm/logs/sme.log
Done with /usr/local/cisco/dcm/fm/logs/sme_accounting_log.2017-07-02-12-00-00.log
Done with /usr/local/cisco/dcm/fm/logs/sme_accounting_log.2017-10-29-12-00-00.log
Done with /usr/local/cisco/dcm/fm/logs/sme_dkr.log
Done with /usr/local/cisco/dcm/fm/logs/sme_accounting_log.2017-07-09-12-00-00.log
Done with /usr/local/cisco/dcm/fm/logs/sme_accounting_log.2017-08-27-12-00-00.log
Done with /usr/local/cisco/dcm/fm/logs/sme_accounting_log.2017-06-25-12-00-00.log
Done with /usr/local/cisco/dcm/fm/logs/sme_accounting_log.2017-07-16-12-00-00.log
Done with /usr/local/cisco/dcm/fm/logs/sme_accounting_log.2017-11-05-12-00-00.log
Done with /usr/local/cisco/dcm/fm/logs/sme_accounting_log.2017-10-17-07-46-48.log
Done with /usr/local/cisco/dcm/fm/logs/sme_accounting_log.2017-06-12-11-12-22.log
Done with /usr/local/cisco/dcm/fm/logs/fm_webreport.log
Done with /usr/local/cisco/dcm/fm/logs/fms_event_manager.log
Done with /usr/local/cisco/dcm/fm/logs/fm_zoneserver.log
Done with /usr/local/cisco/dcm/fm/logs/jboss7.log.1
Done with /usr/local/cisco/dcm/fm/logs/jboss7.log.2
Done with /usr/local/cisco/dcm/fm/logs/epl.log
Done with /usr/local/cisco/dcm/fm/conf/server.properties
Done with /usr/local/cisco/dcm/fm/logs/fms_dump.9
Done with /root/dcnm_installer.log
Done with /usr/local/cisco/dcm/fm/../jboss-as-7.2.0.Final/standalone/log/sanservice.log
Done with /usr/local/cisco/dcm/fm/../smis/server/jserver/logs/jserverlog-6.trace
Done with /usr/local/cisco/dcm/fm/../smis/server/jserver/logs/jserverlog-2.trace
Done with /usr/local/cisco/dcm/fm/../smis/server/jserver/logs/jserverlog-3.trace
Done with /usr/local/cisco/dcm/fm/../smis/server/jserver/logs/jserver.log
Done with /usr/local/cisco/dcm/fm/../smis/server/jserver/logs/jserverlog-0.trace
Done with /usr/local/cisco/dcm/fm/../smis/server/jserver/logs/jserverlog-4.trace
Done with /usr/local/cisco/dcm/fm/../smis/server/jserver/logs/jserverlog-1.trace
Done with /usr/local/cisco/dcm/fm/../smis/server/jserver/logs/jserverlog-5.trace
Done with /usr/local/cisco/dcm/fm/../smis/server/jserver/logs/jserverlog-7.trace
/usr/local/cisco/dcm/fm/logs/techsupport2017-11-08-12-11-35.zip is generated.
Press Enter to exit
Gather Tech-Support Through Linux (OVA Only)
 On some occasions the TAC will ask for a tech-support that encompases more services that are available in DCNM OVA installs.
  • Execute # appmgr tech_support
[root@DCNM ~]# appmgr tech_support
/usr/local/cisco/dcm/smis/client/conf/configuration.properties
/usr/local/cisco/dcm/smis/client/conf/DCNMConnect.xml
/usr/local/cisco/dcm/smis/client/conf/filter.properties
/usr/local/cisco/dcm/smis/server/jserver/schema/brand/rebrand.xml
/usr/local/cisco/dcm/smis/server/jserver/schema/brand/brand.properties
/usr/local/cisco/dcm/smis/server/jserver/bin/hs_err_pid19478.log
/usr/local/cisco/dcm/smis/server/jserver/bin/jservertrace.properties
/usr/local/cisco/dcm/smis/server/jserver/bin/cimom.properties
/usr/local/cisco/dcm/smis/server/jserver/bin/hs_err_pid19470.log
/usr/local/cisco/dcm/smis/server/jserver/bin/hs_err_pid19474.log
/usr/local/cisco/dcm/smis/server/jserver/bin/hs_err_pid20056.log
/usr/local/cisco/dcm/smis/server/jserver/bin/hs_err_pid19486.log
/usr/local/cisco/dcm/smis/server/jserver/bin/hs_err_pid20062.log
/usr/local/cisco/dcm/smis/server/jserver/bin/hs_err_pid19482.log
/usr/local/cisco/dcm/smis/server/jserver/bin/jserver.properties
/usr/local/cisco/dcm/smis/server/jserver/bin/hs_err_pid20048.log
/usr/local/cisco/dcm/smis/server/jserver/bin/hs_err_pid20044.log
/usr/local/cisco/dcm/smis/server/jserver/bin/hs_err_pid20052.log
/usr/local/cisco/dcm/smis/server/jserver/logs/jserver.log
/usr/local/cisco/dcm/smis/server/jserver/logr/provider.properties
/usr/local/cisco/dcm/java/jre1.8/lib/images/cursors/cursors.properties
/usr/local/cisco/dcm/java/jre1.8/lib/javafx.properties
/usr/local/cisco/dcm/java/jre1.8/lib/flavormap.properties
/usr/local/cisco/dcm/java/jre1.8/lib/psfontj2d.properties
/usr/local/cisco/dcm/java/jre1.8/lib/desktop/mime/packages/x-java-archive.xml
/usr/local/cisco/dcm/java/jre1.8/lib/desktop/mime/packages/x-java-jnlp-file.xml
/usr/local/cisco/dcm/java/jre1.8/lib/calendars.properties
/usr/local/cisco/dcm/java/jre1.8/lib/hijrah-config-umalqura.properties
/usr/local/cisco/dcm/java/jre1.8/lib/management/management.properties
/usr/local/cisco/dcm/java/jre1.8/lib/sound.properties
/usr/local/cisco/dcm/java/jre1.8/lib/net.properties
/opt/Python-2.7.3/build/temp.linux-x86_64-2.7/libffi/config.log
/opt/Python-2.7.3/Doc/tools/sphinxext/opensearch.xml
/opt/Python-2.7.3/Lib/test/xmltestdata/simple-ns.xml
/opt/Python-2.7.3/Lib/test/xmltestdata/simple.xml
/opt/Python-2.7.3/Lib/test/xmltestdata/test.xml
/opt/Python-2.7.3/config.log
Logs available at logs_11_08_2017__13_29_28.tar.gz
