pevaneyn
The following is a perl script to call the retrieveTrafficStats call on the central-manager with ip 1.2.3.4 and using the userid admin password default for the WAE called test-wae for the time period of 12:00 until 14:00 UTC on September 27 2010 for the outgoing optimized traffic per hour.
It is just a simple example client for demonstration purposes, if you break something while using this you get to keep both pieces.
#!/usr/bin/perl
use LWP::UserAgent;
# this is the RPC call:
$xml_file = '<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope
  SOAP-ENV:e
ncodingStyle="http://schemas.xmlsoap.org/soap/encoding/"
  xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/"
  xmlns:xsi="http://www.w3.org/1999/XMLSchema-instance"
  xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"
  xmlns:xsd="http://www.w3.org/1999/XMLSchema"
<SOAP-ENV:Header xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd">
<wsse:Security SOAP-ENC:root="1">
<wsse:UsernameToken>
<wsse:Username xsi:type="xsd:string">admin</wsse:Username>
<wsse:Password xsi:type="xsd:string">default</wsse:Password>
</wsse:UsernameToken>
</wsse:Security>
</SOAP-ENV:Header>
<SOAP-ENV:Body>
<ns1:retrieveTrafficStats xmlns:ns1="http://service.stats.ws.waas.cisco.com" SOAP-ENC:root="1">
<name>test-wae</name>
<objType>wae</objType>
<trafficType>optimized</trafficType>
<direction>outbound</direction>
<timeframe>
<startTime xsi:type="xsd:string">2010-09-27T12:00:00</startTime>
<endTime xsi:type="xsd:string">2010-09-27T14:00:00</endTime>
<frequency xsi:type="xsd:string">lasthour</frequency>
<timezone xsi:type="xsd:string">utc</timezone>
</timeframe>
</ns1:retrieveTrafficStats>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>';
my $server      =  '1.2.3.4';
my $port        =  '8443';
my $RPCPath  =  '/ws/TrafficStats';
my $uri = 'https://' . $server . ':' . $port . $RPCPath;
my $ua = LWP::UserAgent->new;
# we need to authenticate the https connection:
$ua->credentials( "", "TrafficStats", "admin", "default" );
my $header = HTTP::Headers->new;
$header->header('SOAPAction' => '"retrieveTrafficStats"');
# this is to define what SOAP RPC call we are making
my $request = HTTP::Request->new("POST",$uri,$header );
$request->content($xml_file);
my $response = $ua->request($request);
print $response->as_string;
print "\n";
This produces output like:
we got back:
HTTP/1.1 200 OK
Connection: close
Date: Tue, 28 Sep 2010 10:53:42 GMT
Server: Apache/1.3.41 (Unix) mod_ssl/2.8.31 OpenSSL/0.9.8g mod_jk/1.2.15 mod_auth_pam/1.0a
Content-Type: text/xml;charset=UTF-8
Client-Date: Tue, 28 Sep 2010 10:53:43 GMT
Client-Peer: 1.2.3.4:8443
Client-Response-Num: 1
Client-SSL-Cert-Issuer: /C=US/ST=California/L=San Jose/OU=CNBU/O=Cisco Systems, Inc/CN=CDN-WAVE-274-1
Client-SSL-Cert-Subject: /C=US/ST=California/L=San Jose/OU=CNBU/O=Cisco Systems, Inc/CN=CDN-WAVE-274-1
Client-SSL-Cipher: DHE-RSA-AES256-SHA
Client-SSL-Warning: Peer certificate not verified
Client-Transfer-Encoding: chunked
<?xml version='1.0' encoding='UTF-8'?><soapenv:Envelope xm....
Jesse De Clerck
Great doc Peter!
