Qiese Dides
Hi Everyone,
I saw a discussion being brought up regarding multicast with UCS. Attached is a power point that combines all the information you need regarding setting up multicast within UCS and on the upstream switch. It will also show you troubleshooting steps to make sure your configuration is working properly.
The power point is attached.
Hope this helps,
Qiese Dides
