change stp mode on nexus 3064pq
malmsteen81
hi,
i have this question. on my network i have all switches aruba cx6300 and a pair of nexus 3064pq  (FW 7.0.3) connected on vpc.
now on all aruba switch the spanning tree is configured as MSTP and on nexus rstp.
So i'm in doubt if change on nexus the spanning tree to mst or disable (on nexus are connected vmware hosts and lacp from other switches). what would you do?
it is possible to disable globaly the spanning tree? and if i will move from rstp to mstp is enough the command
spanning-tree mode mst
 or  i need to change other settings?
thanks
Andrea
No
You need
Spanning-tree mode mst
Spanning-tree mst config
revision <>
Instance <> vlan <>
These revision and instance must be same as Aruba SW
MHM
hi thanks for reply.
So, on aruba i have this settings
MST configuration information
MST config ID : 0c:97:5f:8f:2f:80
MST config revision : 0
MST config digest : AC36177F50283CD4B83821D8AB26DE62
Number of instances : 0
Instance ID Member VLANs
0 1-4094
on nexus i will configure this?
revision 0
Instance 0 vlan 1-4094
right? and priority? on cisco the default is 32768
thanks
Andrea
