04-05-2024 02:46 PM
Can this be fixed or does it need RMA?
ERROR ERROR No bootflash. Rebooting in 30 secs
ERROR ERROR No bootflash. Rebooting in 20 secs
ERROR ERROR No bootflash. Rebooting in 10 secs
CISCO MODULE
BIOS Ver: 5.43
Switch G5
RC Revision: 02.03.00
Memory Information:
MRC Revision:00.50.00
Total DRAM: 24576 MB
Memory TOLM: 80000000
PCIE BASE: 80000000 Size : 10000000
PCI32 BASE: 90000000 Limit: FBFFFFFF
PCI64 BASE: 80000000000 Limit: 83FFFFFFFFF
UC START: 80000000000 End : 84000000000
ME Operational Firmware Version: 06:3.0.3.27
DIMM Information:
Clock Speed: 1067MHz
Socket: 0x0 Channel: 0x0 Number: 0x0 Presence: Yes Size: 16GB
Socket: 0x0 Channel: 0x0 Number: 0x1 Presence: No
Socket: 0x0 Channel: 0x1 Number: 0x0 Presence: Yes Size: 8GB
Socket: 0x0 Channel: 0x1 Number: 0x1 Presence: No
Detected CISCO IOFPGA
Booting from Primary BIOS
Code Signing Results: 0x0
Booting from Upgrade FPGA
IOFPGA Subsystem Vendor ID 0x1172
FPGA Revision : 0x1000020
FPGA ID : 0x1564687
FPGA Date : 0x20190522
Power Debug Register1 : 0x0
Power Debug Register2 : 0x9002f
Reset Cause Register : 0x5
Boot Ctrl Register : 0xe0ff
FPGA Update Status : 0x20
Detected CISCO MIFPGA
MIFPGA Subsystem Vendor ID 0x1172
MIFPGA Version : 0x10
MIFPGA Date : 0x20170515
MIFPGA Update Status : 0x20
MIFPGA ID : 0x1555231
Board Type: SUMPIN
ERROR: ATA device failure
Bootable Disk is not detected. Error code: 0
Version 2.18.1260. Copyright (C) 2020 American Megatrends, Inc.
FPGA SPI Flash Micron(Numonyx) N25Q064A
Board type 4
IOFPGA @ 0xd8000000
SLOT_ID @ 0xf
Set fan speed to 60%
Initializing fan controller...
ERROR ERROR No bootflash. Rebooting in 60 secs
ERROR ERROR No bootflash. Rebooting in 50 secs
ERROR ERROR No bootflash. Rebooting in 40 secs
CISCO MODULE
BIOS Ver: 5.43
Switch G5
Memory Information:
DIMM Information:
FPGA ID : 0x1564687
Board Type: SUMPIN
Board type 4
IOFPGA @ 0xd8000000
SLOT_ID @ 0xf
Aborting config file read and autoboot
No autoboot or failed autoboot. falling to loader
Loader Version 5.43
? Print the command list
boot Boot image
bootmode Display/Change current boot mode
dir List file contents on a device
eobc Booting image from active sup via EOBC channel
help Print the command list or the specific command usage
ip Setting IP address or gateway address
keyinfo BIOS KEY information
reboot Reboot the system
serial Serial console setting
set Set network configuration
show Show loader configuration
dir ?
Error: No Devices Found
dir
04-06-2024 12:22 AM
- FYI : https://bst.cisco.com/bugsearch/bug/CSCvs63505?rfs=qvred
or try fsck bootflash:
M.
