Cisco vpc consistency check
Hi guys,
we have a migration and shifting 2xnexus one by one.
I am doing an upgrade on the Nexus as well.
Just wanted to ask should i disable consistency check for a safety pre-caution just for the migration and disable it and then able it back later or what should be the best thing to do?
Does it matter if consistency check if left disabled?
Sergiu.Daniluk
Hi @saxenanitesh8522
No need to disable consistency check. Just follow the steps from the upgrade guide (upgrade one by one, start with vpc operational secondary etc) and you should be fine.
Stay safe,
Sergiu
