commit failed
Richard Tucker
Frequent Visitor
Frequent Visitor
do any one know how to fix "commit failed" when trying to save the configurations to both local and peer host?
I'm trying to add a vlan to two physical ports e1/7 and e1/8. Its a Nexus 5548 and I just did the command switchport trunk vlan allowed vlan 1,5,7,8 which gave the error.
speritofthunder
Community Member
Dear Richard
To delete commands from the switch-profile buffer, perform the following:
  • View commands in the SP buffer using the show switch-profile buffer command.
  • Delete commands indicated by the sequence numbers with the buffer delete <range> command.
  • Use the buffer-move <seq id> <seq id> command to rearrange commands in the buffer.
This is command is useful when commands in the buffer are not ordered correctly
Hope this help
WN
