Could you check out my config template, I just want to make sure that it makes a domain and works properly, I am about to put it on a production.
thanks a lot
5k-1#Config T
5k-1(Config)#Fex 101
5k-1(Config-Fex)#Pinning max-links 1
5k-1(Config-Fex)#Int te0/1 – 2
5k-1(Config-Fex-if-range)#No sh
5k-1(Config-Fex-if-range)#Switch mode FEX
5k-1(Config-Fex-if-range)#Channel-group 2
5k-1(Config-Fex-if-range)#Int po2
5k-1(Config-if)#Switch mode FEX
5k-1(Config-if)#fex associate 101
5k-2#Config T
5k-2(Config)#Fex 101
5k-2(Config-Fex)#Pinning max-links 1
5k-2(Config-Fex)#Int te0/1 – 2
5k-2(Config-Fex-if-range)#No sh
5k-2(Config-Fex-if-range)#Switch mode FEX
5k-2(Config-Fex-if-range)#Channel-group 2
5k-2(Config-Fex-if-range)#Int po2
5k-2(Config-if)#Switch mode FEX
5k-2(Config-if)#fex associate 101
5k-1(Config)#feature vpc
5k-1(Config)#feature LACP
5k-1(Config)#vpc domain 1
5k-1(Config-vpc-domain)#peer-keepalive destination 11.1.1.2 source 11.1.1.1 vrf management
5k-2(Config)#feature vpc
5k-2(Config)#feature LACP
5k-2(Config)#vpc domain 1
5k-2(Config-vpc-domain)#peer-keepalive destination 11.1.1.1 source 11.1.1.2 vrf management
VPC peer link
5k-1(Config)#int te0/3-4
5k-1(Config-if-range)#no shut
5k-1(Config-if-range)#sw mode trunk
5k-1(Config-if-range)#channel-group 1 mode ac
5k-1(Config-if-range)#int po1
5k-1(Config-if)#no sh
5k-1(Config-if)#swi mode trunk
5k-1(Config-if)#swi trunk allowed vlan all
5k-1(Config-if)#vpc peer-link
5k-2(Config)#int te0/3-4
5k-2(Config-if-range)#no shut
5k-2(Config-if-range)#sw mode trunk
5k-2(Config-if-range)#channel-group 1 mode ac
5k-2(Config-if-range)#int po1
5k-2(Config-if)#no sh
5k-2(Config-if)#swi mode trunk
5k-2(Config-if)#swi trunk allowed vlan all
5k-2(Config-if)#vpc peer-link
