Equipment needed to build vxlan evpn
rkdgus2344
I'm thinking of using Vxlan for my new data center configuration.
The question is are the vxlan evpn equipment rolls fixed?
For example leaf = N9300
spine = N9500
As far as I know, you can use it as a spine if you have the ibgp-rr function.
I think it will be possible with the n9300 as well.
spine = N9K-C93180YC-FX-24
leaf = N9K-C9348GC-FXP
Any problems when using the n9300 as a spine?
Correct. Only as leafs.
Sergiu
Sergiu.Daniluk
Hi @rkdgus2344
First of all, thanks for being part of the community (first question)!
Second, to answer your question: yes, you can have Nexus 9300 familyboth as leaf and as spine, but (there is always a but) only some specific models can be used as leafs, only some specific models can be used as spines, and only some other specific models can be used both as leafs and spines.
To verify which Nexus switches can act as spines and which ones can act as leafs, you can have a look at the compare webpage:
https://www.cisco.com/c/en/us/products/switches/nexus-9000-series-switches/models-comparison.html
For example, the Nexus 9300-40G series , all models can be both spines and leafs, if they are running in NXOS mode.
Nexus 9364C Nexus 9336C-FX2 Nexus 9336C-FX2-E Nexus 9332C Nexus 9364C-GX
Usage ACI spine & NXOS(Leaf/spine), powered by Cloud Scale ACI leaf & NXOS(Leaf/spine), powered by Cloud Scale ACI leaf & NXOS(Leaf/spine), powered by Cloud Scale ACI spine & NXOS(Leaf/spine), powered by Cloud Scale ACI (leaf/spine) & NXOS(Leaf/spine),
https://www.cisco.com/c/dam/en/us/products/switches/nexus-9000-series-switches/nexus-9300-40GE-switches-comparison.html
Stay safe,
Sergiu
Can these be used only as leaf?
thanks
Sergiu
f00z
Level 3
Level 3
Anything can be a spine, the spines only need L3 routing capability for ipv4, like OSPF for example is all the spines need.  The spines do not even need to run BGP or know anything about vxlan or EVPN.  A pair of route reflectors or use some leafs as route reflectors would be needed. Normally the spines act as the route reflectors but it's not necessary.
Anything that supports EVPN should be able to be used as a leaf unless the vendor locks you out of certain things (like being able to make a VTEP) which would be silly.
So for example one could use a nexus 3k as a spine, or even an old 6509, although the latter would be a waste to use.
Above post is EVPN/vxlan only and not related to ACI at all, as that's a proprietary design and you ARE locked into it.
