Error messages after loading the system image Cisco Nexus 3048
beta_admin66
Hello everyone,
I get error messages after loading of the system image and errors after login, although I have set an admin password in boot-config mode.
switch(boot)# load nxos.7.0.3.I4.8a.bin
/etc/rc.d/rcS.d/S99load-isan: line 50: [: ff: integer expression expected
/etc/rc.d/rcS.d/S99load-isan: line 58: [: ff: integer expression expected
Loading System Software Sat Jan 8 23:25:58 UTC 2011
INIT: Switching to runlevel: 3
INIT: Sending processes the TERM signal
INIT: (boot)#
Mounting other filesystems:  [  OK  ]
INIT: c
INIT: cannot execute "/isan/bin/libvirtd.sh"
INIT: cannot execute "/isan/bin/sysmgr_spawn"
INIT: Id "libv" respawning too fast: disabled for 5 minutes
INIT: Id "sm" respawning too fast: disabled for 5 minutes
ERROR: ld.so: object '/isan/lib/libnxoscustom.so' from LD_PRELOAD cannot be prel        oaded: ignored.
User Access Verification
(none) login: admin
ERROR: ld.so: object '/isan/lib/libnxoscustom.so' from LD_PRELOAD cannot be preloaded: ignored.
Password:
Login incorrect
(none) login:
Can anyone help?
Thank you very much.
krzysztofimbor
Hi.
I had similar problem with C3064.
-> Ctrl+C(])
-> write erase (when starts, to erase config)
make a backup of OS incl. kickstart
-> write erase boot
-> reload
-> load OS
-> install all
In my case C3064 it solved the problem multiple times, but I have no clue what is the rootcause
