EVPN+VxLAN arp flood with untagged VLAN
satish.txt1
I am dealing with very strange issue but wanted to check with experts if i am doing anything stupid or not. I have small size EVPN+VxLAN clos network (OSFP+iBGP+Multicast+Arp-suppression (no anycastgateway) is in my setup) very standard configuration. My leafs in vPC for redendency. My leafs connected to HP c7000 bladecenter switch 6120XG.
Problem: On blade server i have two 10G nic (nic1 connected to blade-switch-A and nic2 connected to blade-switch-B) so i have configured bonding active-backup because 6120XG doesn't support MLAG. Everything working great at this point. I have Linux PXE kickstart server and i have dedicated VLAN 70 for PXE which i have untagged on 6120XG switch (because PXE doesn't support VLAN tagging). when i reboot blade server and go to PXE boot to kickstart i can see my PXE get ip address from DHCP but after that it stopped pinging that IP and kickstart failing saying no network connection (in short i can't ping that pxe IP).
I have all my VLAN/VNI configured for arp-suppression. if i remove arp-suppression for PXE VLAN/VNI then everything works, PXE successfully able to kickstart my all servers but as soon as i add arp-suppression it stopped working. Any idea how EVPN+VxLAN handle untagged VLANs?
Leaf NVE1 interface config
interface nve1
  no shutdown
  description ** VTEP/NVE Interface **
  host-reachability protocol bgp
  source-interface loopback1
  member vni 10064
    suppress-arp
    mcast-group 239.1.1.1
  member vni 10065
    suppress-arp
  member vni 10070
    suppress-arp     <---------- if i remove this it then PXE works.
  member vni 10100
    suppress-arp
  member vni 10555 associate-vrf
Bladecenter switch untagged VLAN 70
vlan 70
   name "pxe"
   untagged 1-16
   tagged Trk1
   no ip address
   exit
After debugging i found as soon as PXE boot load start loading CentOS linux at specific place where Linux set VLAN ID 0 on interface to make it native to allow access of all VLAN at that point i have noticed it flood my network with ARP broadcast on that specific VLAN and that cause packet loss on network and my installation stuck.
Look like this untagged frame getting in loop because of arp suppression not sure why. I do have other VLAN also and they are all tagged with VLAN which is working fine without any issue. I haven't seen any issue on them.
[root@pxe-server ~]# tcpdump -i bond0.70 -nn not port 22 and host 10.70.0.112
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on bond0.70, link-type EN10MB (Ethernet), capture size 262144 bytes
13:13:23.115377 ARP, Request who-has 10.70.0.112 (ff:ff:ff:ff:ff:ff) tell 0.0.0.0, length 46
13:13:23.115539 ARP, Request who-has 10.70.0.112 (ff:ff:ff:ff:ff:ff) tell 0.0.0.0, length 46
13:13:23.115974 ARP, Request who-has 10.70.0.112 (ff:ff:ff:ff:ff:ff) tell 0.0.0.0, length 46
13:13:23.116110 ARP, Request who-has 10.70.0.112 (ff:ff:ff:ff:ff:ff) tell 0.0.0.0, length 46
13:13:23.215306 ARP, Request who-has 10.70.0.112 (ff:ff:ff:ff:ff:ff) tell 0.0.0.0, length 46
13:13:23.215312 ARP, Request who-has 10.70.0.112 (ff:ff:ff:ff:ff:ff) tell 0.0.0.0, length 46
13:13:23.215823 ARP, Request who-has 10.70.0.112 (ff:ff:ff:ff:ff:ff) tell 0.0.0.0, length 46
Only way to break this broadcast storm is to remove suppress-arp option from VLAN 70. I think it could be a big in Cisco software because not sure what is the relation of arp with non-tagged frame.
This is my Leaf-1-1 config and Leaf-1-2 is second vPC peer which has pretty similar config. Its very simple network not fancy stuff, I have only 2 vPC pair Leaf as per diagram.
Question: I have enabled suppress-arp on VNI which is pure L2VNI it doesn't have anycast-gateway because my Cisco ASA is gateway for all VLAN. (I am assuming suppress-arp does with L2VNI only without Distributed gateway)
leaf-1-1# show run
cfs eth distribute
nv overlay evpn
feature ospf
feature bgp
feature pim
feature fabric forwarding
feature interface-vlan
feature vn-segment-vlan-based
feature lacp
feature vpc
feature nv overlay
ip domain-lookup
system qos
  service-policy type network-qos jumboframes
fabric forwarding anycast-gateway-mac 0000.dead.beef
ip pim rp-address 10.255.0.123 group-list 239.0.0.0/8
ip pim ssm range 232.0.0.0/8
vlan 1,64-68,70,100,444,555
vlan 64
  name inside
vlan 65
  vn-segment 10065
vlan 66
  vn-segment 10066
vlan 67
  vn-segment 10067
vlan 68
  vn-segment 10068
vlan 70
  name pxe_boot
  vn-segment 10070
vlan 100
  name public
  vn-segment 10100
vlan 444
  name BACKUP_VLAN_ROUTING_VPC
vlan 555
  name L3VNI
  vn-segment 10555
spanning-tree port type edge bpduguard default
spanning-tree loopguard default
spanning-tree vlan 64-68,70,100,555 priority 8192
route-map DIRECT-PERMIT-ALL permit 10
  description ** Route-Map for BGP to redist route **
vrf context CUST1
  vni 10555
  rd auto
  address-family ipv4 unicast
    route-target both auto
    route-target both auto evpn
vrf context management
  ip route 0.0.0.0/0 172.30.0.1
hardware access-list tcam region vacl 0
hardware access-list tcam region arp-ether 256
vpc domain 1
  peer-switch
  role priority 10
  peer-keepalive destination 172.30.0.32 source 172.30.0.31
  delay restore 90
  peer-gateway
  delay restore interface-vlan 30
  ip arp synchronize
interface Vlan1
  no ip redirects
  no ipv6 redirects
interface Vlan100
  description ** Anycast Gateway For Public  **
  no shutdown
  mtu 9216
  vrf member CUST1
  ip address 60.25.124.1/23
  fabric forwarding mode anycast-gateway
interface Vlan444
  description ** Underlay Backup over vPC Peer-Link **
  no shutdown
  ip address 192.168.1.1/30
  ip ospf authentication-key 3 fa3ab8e90610229c
  ip ospf network point-to-point
  ip router ospf UNDERLAY-NET area 0.0.0.0
  ip pim sparse-mode
interface Vlan555
  description ** L3VNI-For-IRB **
  no shutdown
  mtu 9216
  vrf member CUST1
  ip forward
interface port-channel111
  description ** Link to enc-k001-1-a **
  switchport mode trunk
  switchport trunk allowed vlan 64-68,70,100
  mtu 9216
  speed 10000
  vpc 111
interface port-channel112
  description ** Link to enc-k001-1-b **
  mtu 9216
  speed 10000
  vpc 112
interface port-channel121
  description ** Link to enc-k001-2-a **
  mtu 9216
  speed 10000
  vpc 121
interface port-channel122
  description ** Link to enc-k001-2-b **
  mtu 9216
  speed 10000
  vpc 122
interface port-channel211
  description ** Link to enc-k002-1-a **
  mtu 9216
  speed 10000
  vpc 211
interface port-channel212
  description ** Link to enc-k002-1-b **
  mtu 9216
  speed 10000
  vpc 212
interface port-channel221
  description ** Link to enc-k002-2-a **
  mtu 9216
  speed 10000
  vpc 221
interface port-channel222
  description ** Link to enc-k002-2-b **
  mtu 9216
  speed 10000
  vpc 222
interface port-channel311
  description ** Link to enc-k003-1-a **
  mtu 9216
  speed 10000
  vpc 311
interface port-channel312
  description ** Link to enc-k003-1-b **
  mtu 9216
  speed 10000
  vpc 312
interface port-channel321
  description ** Link to enc-k003-2-a **
  mtu 9216
  speed 10000
  vpc 321
interface port-channel322
  description ** Link to enc-k003-2-b **
  mtu 9216
  speed 10000
  vpc 322
interface port-channel999
  description ** vPC Peer-Link **
  switchport trunk allowed vlan 64-68,70,100,444,555
  spanning-tree port type network
  speed 40000
  no negotiate auto
  vpc peer-link
interface nve1
  no shutdown
  member vni 10064
    suppress-arp
  member vni 10065
    suppress-arp
  member vni 10066
    suppress-arp
  member vni 10067
    suppress-arp
  member vni 10068
    suppress-arp
  member vni 10070
  member vni 10100
    suppress-arp
interface Ethernet1/1
  description ** Link to swt-enc-k001-1-a Port E18 **
  no cdp enable
  mtu 9216
  speed 10000
  channel-group 111 mode active
interface Ethernet1/2
  description ** Link to swt-enc-k001-1-a Port E19 **
  no cdp enable
  mtu 9216
  speed 10000
interface Ethernet1/3
  description ** Link to swt-enc-k001-1-b Port E18 **
  no cdp enable
  mtu 9216
  speed 10000
  channel-group 112 mode active
interface Ethernet1/4
  description ** Link to swt-enc-k001-1-b Port E19 **
  no cdp enable
  mtu 9216
  speed 10000
interface Ethernet1/5
  description ** Link to swt-enc-k001-2-a Port E18 **
  no cdp enable
  mtu 9216
  speed 10000
  channel-group 121 mode active
interface Ethernet1/6
  description ** Link to swt-enc-k001-2-a Port E19 **
  no cdp enable
  mtu 9216
  speed 10000
interface Ethernet1/7
  description ** Link to swt-enc-k001-2-b Port E18 **
  no cdp enable
  mtu 9216
  speed 10000
  channel-group 122 mode active
interface Ethernet1/8
  description ** Link to swt-enc-k001-2-b Port E19 **
  no cdp enable
  mtu 9216
  speed 10000
interface Ethernet1/9
  shutdown
  mtu 9216
interface Ethernet1/10
  description ** Link to VMware Host-1 **
  switchport trunk allowed vlan 64-65,70,100
  spanning-tree port type edge trunk
  mtu 9216
  speed 10000
interface Ethernet1/17
  description ** Link to swt-enc-k002-1-a Port E18 **
  no cdp enable
  mtu 9216
  speed 10000
  channel-group 211 mode active
interface Ethernet1/18
  description ** Link to swt-enc-k002-1-a Port E19 **
  no cdp enable
  mtu 9216
  speed 10000
interface Ethernet1/19
  description ** Link to swt-enc-k002-1-b Port E18 **
  no cdp enable
  mtu 9216
  speed 10000
  channel-group 212 mode active
interface Ethernet1/20
  description ** Link to swt-enc-k002-1-b Port E19 **
  no cdp enable
  mtu 9216
  speed 10000
interface Ethernet1/21
  description ** Link to swt-enc-k002-2-a Port E18 **
  no cdp enable
  mtu 9216
  speed 10000
  channel-group 221 mode active
interface Ethernet1/22
  description ** Link to swt-enc-k002-2-a Port E19 **
  no cdp enable
  mtu 9216
  speed 10000
interface Ethernet1/23
  description ** Link to swt-enc-k002-2-b Port E18 **
  no cdp enable
  mtu 9216
  speed 10000
  channel-group 222 mode active
interface Ethernet1/24
  description ** Link to swt-enc-k002-2-b Port E19 **
  no cdp enable
  mtu 9216
  speed 10000
interface Ethernet1/33
  description ** Link to swt-enc-1-a Port E18 **k003
  no cdp enable
  mtu 9216
  speed 10000
  channel-group 311 mode active
interface Ethernet1/34
  description ** Link to swt-enc-k003-1-a Port E19 **
  no cdp enable
  mtu 9216
  speed 10000
interface Ethernet1/35
  description ** Link to swt-enc-k003-1-b Port E18 **
  no cdp enable
  mtu 9216
  speed 10000
  channel-group 312 mode active
interface Ethernet1/36
  description ** Link to swt-enc-k003-1-b Port E19 **
  no cdp enable
  mtu 9216
  speed 10000
interface Ethernet1/37
  description ** Link to swt-enc-2-a Port E18 **k003
  no cdp enable
  mtu 9216
  speed 10000
  channel-group 321 mode active
interface Ethernet1/38
  description ** Link to swt-enc-k003-2-a Port E19 **
  no cdp enable
  mtu 9216
  speed 10000
interface Ethernet1/39
  description ** Link to swt-enc-k003-2-b Port E18 **
  no cdp enable
  mtu 9216
  speed 10000
  channel-group 322 mode active
interface Ethernet1/40
  description ** Link to swt-enc-k003-2-b Port E19 **
  no cdp enable
  mtu 9216
  speed 10000
interface Ethernet2/1
  description ** Spine-1 **
  no switchport
  mtu 9216
  medium p2p
  ip address 10.1.11.1/31
  ip ospf authentication-key 3 XXXXXXX
  ip pim sparse-mode
  no shutdown
interface Ethernet2/2
  description ** Spine-2 **
  no switchport
  mtu 9216
  medium p2p
  ip address 10.2.11.1/31
  ip pim sparse-mode
  no shutdown
interface Ethernet2/11
  speed 40000
  no negotiate auto
  channel-group 999 mode active
interface Ethernet2/12
  speed 40000
  no negotiate auto
interface mgmt0
  vrf member management
  no ip redirects
  ip address 172.30.0.31/23
interface loopback0
  description ** RID/BGP Overlay **
  ip address 10.255.1.11/32
  ip pim sparse-mode
interface loopback1
  description ** VTEP/Overlay **
  ip address 10.255.255.11/32
  ip address 10.255.255.10/32 secondary
  ip pim sparse-mode
cli alias name wr copy running-config startup-config
line console
line vty
boot nxos bootflash:/nxos.9.3.4.bin
  router-id 10.255.1.11
  log-adjacency-changes
  area 0.0.0.0 authentication
router bgp 65001
  log-neighbor-changes
  template peer VXLAN_SPINE
    remote-as 65001
    update-source loopback0
    address-family l2vpn evpn
      send-community
      send-community extended
  neighbor 10.255.0.1
    inherit peer VXLAN_SPINE
    description ** iBGP Peer to Spine-1 **
  neighbor 10.255.0.2
    description ** iBGP Peer to Spine-2 **
  vrf CUST1
      redistribute direct route-map DIRECT-PERMIT-ALL
evpn
  vni 10064 l2
    rd auto
    route-target import auto
    route-target export auto
  vni 10065 l2
    rd auto
  vni 10066 l2
    rd auto
  vni 10067 l2
    rd auto
  vni 10068 l2
    rd auto
  vni 10070 l2
    rd auto
  vni 10100 l2
    rd auto
hzg
I have the same error. From your linux tcpdump, linux send a arp probe packet, not a traditional arp request. The arp probe packet check duplicate ip address. when your network don't exist the same IP, the arp-probe request can't receive arp-annoucement reply, so mac-ip mapping can't complete. When arp-suppression is enabled, it can't complete mac-ip mapping, that causes arp-flooding.
My english is poor.I'm sorry.
hzg
ARP suppression is only supported for a VNI if the VTEP hosts the first hop anycast gateway for this VNI.  Shut/no shut the NVE interface after removing suppress arp Note: This will affect other VLANS/VNI’s. This procedure is considered disruptive
hzg
You can also read this article:https://routingcraft.net/arp-problems-in-evpn/
